  • wifi模块,传输图片。希望大佬回复
    • 想实现的功能:先拍一张照片,保存到sd卡里面,然后手机链接wifi模块的热点之后,输入ip地址,可以一直看到那一张照片。希望有技术人员能提供代码参考。
    • 参考传mjpeg视频流的例程
      http://book.openmv.cc/example/14-WiFi-Shield/mjpeg-streamer.html
      去掉while循环,就是仅传一次图片
    • 去掉while,改if吗?
    • 节后上班我回去试一下,header应该也需要改⁄(⁄ ⁄ ⁄ω⁄ ⁄ ⁄)⁄
    • 请问一下,节后是什么时候?我有点赶时间,现在能不能指点一下?
    • @yuan 大佬,我把while改了if,但是连接wifi并不能看到哪一张照片,直接被刷过去了。给你看这个图!![0_1523006546556_F1C58~C~F310RA}WTN9(3N.png
    • 加入了传输图片的程序
      http://book.openmv.cc/shield/wifi.html
      import sensor, image, time, network, usocket, sys
      KEY  ='1234567890'    # Network key (must be 10 chars)
      HOST = ''           # Use first available interface
      # Reset sensor
      # Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      # Init wlan module in AP mode.
      # You can block waiting for client to connect
      def response(s):
          client, addr = s.accept()
          # set client socket timeout to 2s
          client.settimeout(2.0)
          # Read request from client
          data = client.recv(1024)
          # Should parse client request here
          # Send multipart header
                      "Server: OpenMV\r\n" \
                      "Content-Type: image/jpeg\r\n\r\n")
          # FPS clock
          # Start streaming images
          # NOTE: Disable IDE preview to increase streaming FPS.
          frame = sensor.snapshot()
          cframe = frame.compressed(quality=35)
          client.send(cframe)
          client.close()
          # Create server socket
              # Bind and listen
              s.bind([HOST, PORT])
              s.listen(5)
              # Set server socket timeout
              # NOTE: Due to a WINC FW bug, the server socket must be closed and reopened if
              # the client disconnects. Use a timeout here to close and re-create the socket.
              s.settimeout(3)
              response(s)
          except OSError as e:
              s.close()
              print("socket error: ", e)
              #sys.print_exception(e)
    • 谢谢大佬,但是刚刚我用其它方法已经搞定了。
