  • 识别不同颜色色块,找到每个颜色色块的最大色块,为什么识别不出来呢?程序哪里出错了呢?
    • # Multi Color Blob Tracking Example
      # This example shows off multi color blob tracking using the OpenMV Cam.
      red = (22, 67, 19, 84, -12, 53)# generic_red_thresholds
      black= (0, 31, -34, 41, 24, -21)# generic_black_thresholds
      # camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
      def find_max(blobs):    #寻找最大色块函数定义
           max_pixels=0         #通过像素比较
           for blob in blobs:     #blob[0,1,2,3,4]=x,y,w,h,pixels (int)
               if blob[4]>max_pixels:
                   max_pixels=blob[4]
          red_blobs= img.find_blobs([red])
          black_blobs= img.find_blobs([black])
      if red_blobs:
             max_blob_red=find_max(red_blobs)
             img.draw_rectangle(max_blob_red.rect())
             img.draw_cross(max_blob_red.cx(),max_blob_red.cy())
             red_x_error = int(max_blob_red.cx()-img.width()/2)
             red_y_error = int(max_blob_red.cy()-img.height()/2)
      if black_blobs:
             max_blob_black=find_max(black_blobs)
             img.draw_rectangle(max_blob_black.rect())
             img.draw_cross(max_blob_black.cx(),max_blob_black.cy())
             black_x_error = int(max_blob_black.cx()-img.width()/2)
             black_y_error = int(max_blob_black.cy()-img.height()/2)
      #print(blob.code())
    • 缩进不对,导致逻辑不对。
