为什么霍夫变换检测到的直线不稳定呢
一会有一会没有,这是什么导致的啊
请提供代码和图片。
fuc_threshold_01 = (49, 100, 43, 120, -128, 22)
red_threshold_01 = (0, 100, -38, 127, 39, 127)
green_threshold_01 = (62, 75, -100, -18, -4, 127)
vio_threshold_01 = (0, 53, -128, 34, -128, -1)sensor.reset() # Initialize the camera sensor.
sensor.set_framesize(sensor.QQVGA) # use QVGA for quailtiy ,use QQVGA for speed.
min_degree = 0
max_degree = 179
扩宽roi
def expand_roi(roi):
# set for QQVGA 160120
extra = 5
win_size = (160, 120)
(x, y, width, height) = roi
new_roi = [x-extra, y-extra, width+2extra, height+2*extra]if new_roi[0] < 0: new_roi[0] = 0 if new_roi[1] < 0: new_roi[1] = 0 if new_roi[2] > win_size[0]: new_roi[2] = win_size[0] if new_roi[3] > win_size[1]: new_roi[3] = win_size[1] return tuple(new_roi)
# pixels_threshold=100, area_threshold=100
blobs = img.find_blobs([red_threshold_01], area_threshold=150)
blobs2 = img.find_blobs([green_threshold_01], area_threshold=150)
blobs3 = img.find_blobs([fuc_threshold_01], area_threshold=150)
blobs4 = img.find_blobs([vio_threshold_01], area_threshold=150)if blobs3: # print(blobs) for blob in blobs3: #迭代找到的目标颜色区域 is_circle = False max_circle = None max_radius = -1 new_roi = expand_roi(blob.rect()) for l in img.find_lines(threshold =2000, theta_margin = 1, rho_margin =1,roi=new_roi): if (min_degree <= l.theta()) and (l.theta() <= max_degree): img.draw_line(l.line(), color = (255, 255, 0)) # print(l) print(clock.fps())
我运行你的程序一直找不到。
