  • 串口接收和摄像头冲突
      # UART Control
      # This example shows how to use the serial port on your OpenMV Cam. Attach pin
      # P4 to the serial input of a serial LCD screen to see "Hello World!" printed
      # on the serial LCD display.
      import pyb
      threshold_index = 0 # 0 for red, 1 for green, 2 for blue
      thresholds = [(5, 100, 30, 127, 0, 80), # generic_red_thresholds
                    (5, 100, -127, -20, 0, 80), # generic_green_thresholds
                    (5, 100, -20, 30, -127, -20)] # generic_blue_thresholds
      led = pyb.LED(3)
      # Always pass UART 3 for the UART number for your OpenMV Cam.
      # The second argument is the UART baud rate. For a more advanced UART control
      # example see the BLE-Shield driver.
      flag = 0
      cnt = 0
      x = 0
      y = 0
          #output = "%d"%(3)
          #uart.write(output)
          if uart.any():
            a = uart.readline().decode().strip()
            print(a)
            flag = int(a)
            print(flag)
          if flag == 1:
         # uart.write("Hello World!\r")
         # time.sleep(100)
      发送的数据为 1 或者 2
      单片机端代码
               sprintf(printbuff1, "1\r\n");                  //显示
               uart_putstr(UART1,printbuff1);
      会出现图中的错误,怎么解决呢
    • 你应该用串口助手试一下,我不知道你单片机的函数有没有混进去什么奇怪的东西。
