  • Openmv的rgb灯
    • 在追小球的例程中,开了补光灯,为什么当rgb灯闪红色的时候,补光灯就不亮了,就无法追小球了?
    • 不知道什么情况。
      能否给出一个复现故障的步骤?
    • #2018.8.2
      import sensor, image, time , pyb
      from pyb import Timer
      from pyb import LED
      led = pyb.LED(3) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
      thresholds = [(27, 67, 19, 91, 45, 76), # 红色
                    #(21, 75, 3, -38, 34, 68), # 绿色
                    (27, 90, -3, -28, 31, 125),
                    (0, 30, 0, 64, -128, 0)]  # generic_blue_thresholds
      threshold_index = 1 # 0 for red, 1 for gre9en, 2 for blue
      sensor.set_framesize(sensor.QVGA)   #320*240
      sensor.skip_frames(time = 100)
      uart.init(115200, bits=8, parity=None, stop=1, timeout_char=1000) # 使用给定参数初始化
      def tick(timer):            # we will receive the timer object when being called
          global data
              print("Find")
              print('you send:',output_str)
              uart.write(data)
      tim = Timer(4, freq=10)      # create a timer object using timer 4 - trigger at 1Hz
      tim.callback(tick)          # set the callback to our tick function
      def Uart_Receive():   #UART接收 改变框小球的颜色阈值
          global threshold_index
          if uart.any():
              temp_data = uart.readchar()
              if temp_data==0:   #红色
                 threshold_index=0
                 print(temp_data,threshold_index)
              elif temp_data==1:
                 threshold_index=1
          Uart_Receive()
          blobs = img.find_blobs([thresholds[threshold_index]])
              max_blob = find_max(blobs)
              b = max_blob[0] #方框元组
              L = (max_blob[2]+max_blob[3])/2
              l=int(1000/L)
              #x_error = max_blob[5]-img.width()/2   #求横向偏差
              img.draw_rectangle(max_blob[0:4])        # 画矩形
              img.draw_cross(max_blob[5], max_blob[6]) # 画十字
              #发送 小球的(x,y,l,n)
              #x为横坐标,y为纵坐标,l为粗略的距离,n为小球颜色(0:红 1:绿)
              output_str="%d,%d,%d,%d" % (max_blob.cx(),max_blob.cy(),l,threshold_index) #10进制字符包
              checkout=0xAA+0x55+0x07+int(max_blob.cx()/2)+max_blob.cy()+l+threshold_index
              data = bytearray([0xAA,0x55,0x07,int(max_blob.cx()/2),max_blob.cy(),l,threshold_index,0x00,0x00,checkout])#转成16进制
              #uart.write(data)
              time.sleep(1)
              led.on()
              print("NO FIND")
              data = bytearray([0xAA,0x55,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x06])
              uart.write(data)
              led.off()
      这段代码连接32,在追小球的过程中,代码里面有补光灯的设置,所以一开始补光灯是亮着的,追小球也没问题,但是找不到小球的时候,突然就闪红灯,随后补光灯也不亮了,就无法追小球了。
    • 可能是程序出错了,你用OpenMV IDE运行程序,应该可以看到出错信息。
    • 程序没有问题还可以运行啊,就是运行以后才突然不行的
    • @h2my 可能是运行过程中出错的。
