import pyb, ustruct # ustruct 用于打包和解压原始数据类型 的 "类"
import gc
sensor.skip_frames(time = 300)
K=560#the value should be measure
bus = pyb.I2C(2, pyb.I2C.SLAVE, addr=0x12)
bus.deinit() # 完全关闭设备
print("Waiting for Arduino...")
length=0
circlex=0
circley=0
for c in img.find_circles(threshold = 2000, x_margin = 10, y_margin = 10, r_margin = 10,
circlex=c.x()
circley=c.y()
img.draw_rectangle(area, color = (255, 255, 255))#将非红色的圆用白色的矩形框出来
Lm = 2*c.r()
length = K/Lm
#print("FPS %f" % clock.fps())
print("length:",length)
output_str=[length,circlex,circley]
for i in range(3):
data = output_str[i]
#sensor.shutdown(True)
#try:
#bus.send(4, timeout=10000) # Send the len first (16-bits).
bus.send(data, timeout=10000) # Send the data second.
print(data)
print("Sent Data!") # Only reached on no error.
except OSError as err:
pass # Don't care about errors - so pass.
# Note that there are 3 possible errors. A timeout error, a general purpose error, or
# a busy error. The error codes are 116, 5, 16 respectively for "err.arg[0]".
#except OSError as err:
#pass
del img
gc.collect()
![0_1684415443045_屏幕截图 2023-05-18 211022.png](https://fcdn.singtown.com/95586d9d-64a8-4183-9c0b-5b51f5c9c481.png)
