为什么脱机运行WiFi视频流传输,总是断网
MJPEG Streaming AP.
这个例子展示了如何在AccessPoint模式下进行MJPEG流式传输。
Android上的Chrome,Firefox和MJpegViewer App已经过测试。
连接到OPENMV_AP并使用此URL:http://192.168.1.1:8080查看流。
import sensor, image, time, network, usocket, sys, math, ustruct
from pid import PIDuart = UART(3,115200,bits=8, parity=None, stop=1, timeout_char = 1000)
GRAYSCALE_THRESHOLD = [(0, 64)]
ROIS = [ # [ROI, weight]
(0, 100, 160, 20, 0.7),
(0, 050, 160, 20, 0.3),
(0, 000, 160, 20, 0.4)
weight_sum = 0
for r in ROIS: weight_sum += r[4]SSID ='OPENMV_AP' # Network SSID
KEY ='1234567890' # wifi密码(必须为10字符)
HOST = '' # 使用第一个可用的端口
PORT = 8080 # 任意非特权端口sensor.reset()
sensor.set_brightness(1)
sensor.set_saturation(1)
sensor.set_auto_gain(False)
#sensor.set_vflip(True)
#sensor.set_hmirror(True)wlan = network.WINC(mode=network.WINC.MODE_AP)
wlan.start_ap(SSID, key=KEY, security=wlan.WEP, channel=2)def start_streaming(s):
def sending_data(data): global uart; data = ustruct.pack("<bbb", x, 0x0d, 0x0a ) uart.write(data); print ('Waiting for connections..') client, addr = s.accept() # 将客户端套接字超时设置为2秒 client.settimeout(2.0) print ('Connected to ' + addr[0] + ':' + str(addr[1])) # 从客户端读取请求 data = client.recv(1024) # 应该在这里解析客户端请求 # 发送多部分head client.send("HTTP/1.1 200 OK\r\n" \ "Server: OpenMV\r\n" \ "Content-Type: multipart/x-mixed-replace;boundary=openmv\r\n" \ "Cache-Control: no-cache\r\n" \ "Pragma: no-cache\r\n\r\n") # FPS clock clock = time.clock() a=0 n=0 # 开始流媒体图像 #注:禁用IDE预览以增加流式FPS。 while (True): if uart.any(): a = uart.read(1) print(a[0]) if a[0]==0x00: img = sensor.snapshot().binary(GRAYSCALE_THRESHOLD).invert() cframe = img.compressed(quality=35) header = "\r\n--openmv\r\n" \ "Content-Type: image/jpeg\r\n"\ "Content-Length:"+str(cframe.size())+"\r\n\r\n" client.send(header) client.send(cframe) centroid_sum = 0 most_pixels = 5000 for r in ROIS: blobs = img.find_blobs(GRAYSCALE_THRESHOLD, roi=r[0:4], merge=True) if blobs: largest_blob = 0 for i in range(len(blobs)): if blobs[i].pixels() > most_pixels: most_pixels = blobs[i].pixels() largest_blob = i img.draw_rectangle(blobs[largest_blob].rect()) img.draw_cross(blobs[largest_blob].cx(), blobs[largest_blob].cy()) centroid_sum += blobs[largest_blob].cx() * r[4] center_pos = (centroid_sum / weight_sum) deflection_angle = 0 deflection_angle = -math.atan((center_pos-80)/60) deflection_angle = math.degrees(deflection_angle) x = int(deflection_angle) sending_data(x) print("Turn Angle: %d" % deflection_angle) if a[0]==0x01: img = sensor.snapshot() sensor.set_pixformat(sensor.RGB565) cframe = img.compressed(quality=35) header = "\r\n--openmv\r\n" \ "Content-Type: image/jpeg\r\n"\ "Content-Length:"+str(cframe.size())+"\r\n\r\n" client.send(header) client.send(cframe) sensor.snapshot().save("singtown%s.jpg" % (n) ) n +=1 #print(n)
# 创建服务器套接字
# Bind and listen
s.bind([HOST, PORT])
s.listen(5)# 设置服务器套接字超时 # 注意:由于WINC FW bug,如果客户端断开连接,服务器套接字必须 # 关闭并重新打开。在这里使用超时关闭并重新创建套接字。 s.settimeout(3) start_streaming(s) except OSError as e: s.close() print("socket error: ", e) #sys.print_exception(e)
