  • 用FOMO算法识别出来目标后想用它得到的中心坐标控制云台,但是云台只向下转动到最低就没反应了
      import sensor, image, time, os, tf, math, uos, gc, tv
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
      tv.init(triple_buffer=False) # 初始化tv
      tv.channel(8) # 用于无线图传扩展板
          # of our objects
          result = net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])
          print(result)
          for i, detection_list in enumerate(result):
              for d in detection_list:
                  [x, y, w, h] = d.rect()
                  pan_error = center_x-img.width()
                  tilt_error = center_y-img.height()
                  print(pan_error , pan_error)
                  pan_output=pan_pid.get_pid(pan_error,1)
                  print(pan_output,pan_output)
          tv.display(sensor.snapshot()) # 拍照并显示图像
        #  print('x %d\ty %d' % (math.floor(x + (w / 2)),  math.floor(y + (h / 2)))
