  • 用云台人脸追踪时舵机只会向上移动不会向下并且向右移动比向左移动灵敏是怎么回事
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      pan_pid = PID(p=0.07, i=0, imax=90)
      tilt_pid = PID(p=0.05, i=0, imax=90)
      sensor.set_vflip(True)
      from pyb import millis
      from math import pi, isnan
      class PID:
      	_RC = 1/(2 * pi * 20)
      		self._kp = float(p)
      		self._ki = float(i)
      		self._kd = float(d)
      		self._imax = abs(imax)
      		tnow = millis()
      		dt = tnow - self._last_t
      		output = 0
      			dt = 0
      			self.reset_I()
      		self._last_t = tnow
      		output += error * self._kp
      				derivative = 0
      				self._last_derivative = 0
      			self._last_error = error
      		output *= scaler
      			output += self._integrator
      		return output
      	def reset_I(self):
      		self._integrator = 0
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
          img.draw_cross(int(max_blob[0]+max_blob[2]/2), max_blob[1]+int(max_blob[3]/2-img.height()/2)) # cx, cy
