  • 神经网络学习完数据集导入报错
    • 报错如下:Exception: Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (Arena size is too small for all buffers. Needed 399408 but only 269008 was available.
      求解决办法!!!
      代码如下:
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
    • 朋友我想问一下那个网站你卡不卡😢
    • 卡,卡的一塌糊涂,外网都这样
    • 用个加速器可能会好一点
