  • 例子中的瞳孔识别不准确,有时识别不出来有时识别出来的只有一个眼睛
    • # Iris Detection 2 Example
      # This example shows how to find the eye gaze (pupil detection) after finding
      # the eyes in an image. This script uses the find_eyes function which determines
      # the center point of roi that should contain a pupil. It does this by basically
      # finding the center of the darkest area in the eye roi which is the pupil center.
      # Note: This script does not detect a face first, use it with the telephoto lens.
      import sensor, time, image
      # Reset sensor
      # Sensor settings
      sensor.set_contrast(3)
      # Set resolution to VGA.
      # Bin/Crop image to 200x100, which gives more details with less data to process
      sensor.set_windowing((220, 190, 200, 100))
      # Load Haar Cascade
      eyes_cascade = image.HaarCascade("eye", stages=24)
      print(eyes_cascade)
      # FPS clock
          # Capture snapshot
          # Find eyes !
          eyes = img.find_features(eyes_cascade, threshold=0.5, scale_factor=1.5)
          # Find iris
          for e in eyes:
              iris = img.find_eye(e)
              img.draw_rectangle(e)
              img.draw_cross(iris[0], iris[1])
          # Print FPS.
          # Note: Actual FPS is higher, streaming the FB makes it slower.
    • 例程讲解-08-face_eye_detection人眼追踪
      可以试一下人眼追踪。
      人眼追踪是先识别人脸,然后识别眼睛。
      瞳孔追踪是先识别眼睛,然后寻找眼睛中颜色最深的部位确定为瞳孔,并且需要配合长焦镜头使用。
