刚刚接触OpenMV,python没学过语法有点看不懂,那个大佬能帮我把下面两段代码合在一起吗,现在急用,非常感谢
代码1:
import sensor, image, time from pyb import UART from pyb import LED sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.set_windowing((200, 200)) sensor.set_hmirror(True) sensor.set_vflip(True) sensor.skip_frames(30) sensor.set_auto_gain(False, gain_db=13) sensor.set_auto_whitebal(False) uart = UART(3, 115200, timeout_char=1000) uart.init(115200, bits=8, parity=None, stop=1) clock = time.clock() led_R = LED(1) led_G = LED(2) threshold = (97, 100, -5, 8, -5, 8) while(True): clock.tick() img = sensor.snapshot() img.binary([threshold]) circles = img.find_circles(threshold = 5000, x_margin = 10, y_margin = 10, r_margin = 10, r_min = 3, r_max = 50, r_step = 1) img = sensor.snapshot() for c in circles: area = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r()) print(c) statistics = img.get_statistics(roi=area) rgb_c_l = img.get_pixel(c.x()-c.r()-8, c.y()) rgb_c_r = img.get_pixel(c.x()+c.r()+8, c.y()) rgb_c_u = img.get_pixel(c.x(), c.y()-c.r()-8) rgb_c_d = img.get_pixel(c.x(), c.y()+c.r()+8) if rgb_c_l==None or rgb_c_r==None or rgb_c_u==None or rgb_c_d==None: continue rgb_c = [0, 0, 0] rgb_c[0] = (rgb_c_l[0] + rgb_c_r[0] + rgb_c_u[0] + rgb_c_d[0]) // 4 rgb_c[1] = (rgb_c_l[1] + rgb_c_r[1] + rgb_c_u[1] + rgb_c_d[1]) // 4 rgb_c[2] = (rgb_c_l[2] + rgb_c_r[2] + rgb_c_u[2] + AAAAAAAAAAAAAA[2]) // 4 print(rgb_c) if 220<=rgb_c[0] and rgb_c[1]+50<rgb_c[0] and rgb_c[2]+50<rgb_c[0]: img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0)) print('traffic light is red') uart.write('traffic light is red') led_R.on() elif rgb_c[0]+80<rgb_c[1] and 220<=rgb_c[1] and rgb_c[2]+50<rgb_c[1]: img.draw_circle(c.x(), c.y(), c.r(), color = (0, 255, 0)) print('traffic light is green') uart.write('traffic light is green') led_G.on() elif 220<=rgb_c[0] and rgb_c[1]+80<=rgb_c[0] and rgb_c[2]+150<rgb_c[0]: img.draw_circle(c.x(), c.y(), c.r(), color = (255, 255, 0)) print('traffic light is yellow') uart.write('traffic light is yellow') else: led_R.off() led_G.off()
代码二
import sensor, image sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) # can be QVGA on M7... sensor.skip_frames(30) sensor.set_auto_gain(False) # must turn this off to prevent image washout... while(True): img = sensor.snapshot() img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens. for code in img.find_qrcodes(): print(code)
结果:
