  • 为什么在中文文档中找的方法报错?
      green_threshold   = (   66,   80,  -15,   0,   -6,   15)
      sensor.set_auto_gain(False)
          print(type(img))
          print(blobs.corners())
              for b in blobs:
                  img.draw_rectangle(b[0:4])
                  for i in range(4):
                      print(b[i])
                  img.draw_cross(b[5], b[6])
                  uart.write("x:")
                  uart.write(str(b[5]))
                  uart.write("y:")
                  uart.write(str(b[6]))
                  uart.write("\r\n")
                  print("x:"+str(b[5])+","+"y:"+str(b[6]))
          #print(clock.fps()) # 注意: 你的OpenMV连到电脑后帧率大概为原来的一半
      File "", line 77, in
      AttributeError: 'list' object has no attribute 'corners'
      MicroPython: v1.15-r32 OpenMV: v4.0.2 HAL: v1.9.0 BOARD: OPENMV4P-STM32H743
      Type "help()" for more information.
      我这样使用就会报这样的错
      主要是想问大家这个东西该怎么用
    • find_blobs返回的是列表,里面包含很多个blob对象,尝试用for blob in blobs:来打印每一个blob的conners
