  • 这段程序不能正常转弯,应该怎么改代码
      import car
      from time import sleep
      from pyb import Pin
      sensor.skip_frames(10)
      green_threshold   = (46, 65, -53, -16, 18, 66)
      size_threshold = 2000
      x_pid = PID(p=0.1, i=1, imax=100)
              print("x error: ", x_error)
              img.draw_rectangle(max_blob[0:4])
              img.draw_cross(max_blob[5], max_blob[6])
              print("h_output",h_output)
              sleep(0.1)
              car.run(26,-26)
