  • 特征点匹配过程中经常出现descriptors have different types!报错,怎么解决啊?
      sensor.set_contrast(3)
          if kpts:
              print(kpts)
              img.draw_keypoints(kpts)
              time.sleep_ms(1000)
      thresholds = (61, 255)
          kptsF = image.load_descriptor("kptsBF.orb")
          kptsC = image.load_descriptor("kptsBC.orb")
          img.binary([(0, 100, 11, 127, -2, 30),(16, 57, -24, -12, -28, 3)])
          img.to_grayscale
          for blob in img.find_blobs([thresholds], pixels_threshold=50, merge=False):#10米处50cm大小约为13像素
              pixel = blob.pixels()
              kpts2 = img.find_keypoints(max_keypoints=150, threshold=1, normalized=True)
              if (pixel < 4900):#距离较远,图像不够清晰时
                  match = image.match_descriptor(kptsF, kpts2, threshold=85)
              elif (pixel > 4900):#距离较近,图像清晰时
                  match = image.match_descriptor(kptsC, kpts2, threshold=85)
              if (match.count()>1):
                  print("matched:%d dt:%d  x:%d y:%d"%(match.count(), match.theta(),blob.w(), blob.h()))
