import pyb
import wifi
from pyb import Servo
from pyb import Pin, Timer
pan_servo=Servo(1)
tilt_servo=Servo(2)
led = pyb.LED(3)
green_threshold = (31, 100, -100, -44, -2, 69)
pan_pid = PID(p=0.07, i=0, imax=90)
tilt_pid = PID(p=0.05, i=0, imax=90)
sensor.set_brightness(1)
sensor.set_saturation(1)
# Init wlan module in AP mode.
# You can block waiting for client to connect
objects = img.to_grayscale().find_features(face_cascade, threshold=0.75, scale=1.35)
elif objects:
led.on()
time.sleep_ms(150) #延时150ms
led.off()
# Create server socket
# Bind and listen
s.bind([HOST, PORT])
s.listen(5)
# Set server socket timeout
s.settimeout(3)
wifi.start_streaming(s)
except OSError as e:
s.close()
print("socket error: ", e)
#sys.print_exception(e)
