  • 这个代码能不能给我翻译一遍
      from pyb import LED
      led = LED(3)
      uart = UART(1, 19200)
      uart.init(115200,bits=8,parity=None,stop=1)
      thresholds = [(23, 90, -62, -5, 9, 68), #绿色
                    (10,70, -5, 37, -71, -30),#蓝色
                    (0, 15, -19, 2, 2, 21),# 黑色
                    (0, 100, -128, 127, -128, 127)]#全色
      sensor.skip_frames(time = 200)
      sensor.set_auto_gain(False)
          blobs=[]
      #    nothing=img.find_blobs([thresholds[3]])
          blobs=img.find_blobs([thresholds[0],thresholds[1],thresholds[2]], pixels_threshold=5, area_threshold=5, merge=True)
          max_b=find_max(blobs)
          if max_b.code()==1:
                   led.off()
                   uart.write('1')
                   img.draw_rectangle(max_b[0:4],color=(0,255,0))
                   img.draw_cross(max_b[5],max_b[6],color=(255,0,0))
                   print("green")
          elif max_b.code()==2:
                  led.off()
                  uart.write('2')
                  img.draw_rectangle(max_b[0:4],color=(255,0,0))
                  img.draw_cross(max_b[5],max_b[6],color=(0,255,0))
                  print("blue")
                led.off()
      #    if max_b.code()==3:
      #            uart.write('1')
      #            img.draw_rectangle(max_b[0:4],color=(0,0,255))
      #            img.draw_cross(max_b[5],max_b[6],color=(0,0,255))
      #            print("black")
