  • 关于视觉识别后的结果通过串口发送到其他设备 要怎么做
    • Single Color RGB565 Blob Tracking Example
      This example shows off single color RGB565 tracking using the OpenMV Cam.
      Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
      The below thresholds track in general red/green/blue things. You may wish to tune them...
      (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds
      Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are
      returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the
      camera resolution. "merge=True" merges all overlapping blobs in the image.
      for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True):
      这个是openMV自带的单颜色识别,
      UART Control 串口通信
      uart.write("Hello World!\r")
      print("Hello World")
      # 休眠1s
      time.sleep(1000)
      这个是向串口发送数据的代码
      现在要实现 在OPENMV用自带的代码 进行单颜色识别 识别了颜色后会发出一个信号符或标识符, 通过串口发送到
      TTL 转接到PC上的串口的显示 从而进行单片机之间的通信
      例如, 识别了红色后 发出一个1或red的信号 通过串口 发送到 串口调试助手, 显示出1或red
      这两个代码要怎么结合 做才能达到这个效果,, PYthon新手,求各位大神指导
