  • 我用WiFi的历程发送mjpeg视频流到pc端的charm浏览器上,fps始终只有2左右
    • 0_1587287202185_无标题.png 请在这里粘贴代码
      # MJPEG Streaming
      # This example shows off how to do MJPEG streaming to a FIREFOX webrowser
      # Chrome, Firefox and MJpegViewer App on Android have been tested.
      # Connect to the IP address/port printed out from ifconfig to view the stream.
      SSID =''     # Network SSID
      KEY  =''     # Network key
      HOST =''     # Use first available interface
      PORT = 8080  # Arbitrary non-privileged port
      # Reset sensor
      # Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      # Init wlan module and connect to network
      print("Trying to connect... (may take a while)...")
      wlan = network.WINC()
      # We should have a valid IP now via DHCP
      print(wlan.ifconfig())
      # Create server socket
      # Bind and listen
      s.bind([HOST, PORT])
      s.listen(5)
      # Set server socket to blocking
      s.setblocking(True)
      def start_streaming(s):
          client, addr = s.accept()
          client.settimeout(2.0)
          # Read request from client
          data = client.recv(1024)
          # Send multipart header
                      "Server: OpenMV\r\n" \
                      "Pragma: no-cache\r\n\r\n")
          # FPS clock
          # Start streaming images
              frame = sensor.snapshot()
              header = "\r\n--openmv\r\n" \
              client.send(header)
              client.send(cframe)
              start_streaming(s)
          except OSError as e:
              print("socket error: ", e)
              #sys.print_exception(e)
