  • socket传输图片未能传输完全,代码如何修改?
    • 已封禁
      socket传输的图片效果
      openmv客户端
      # Reset sensor
      # Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      sensor.set_auto_gain(True)
      sensor.set_auto_whitebal(True)
      SSID='*******'
      KEY='*******'
      wlan = network.WINC()
      print(wlan.ifconfig())
      addr=("******",20000)
      # connect to serve
      client = usocket.socket(usocket.AF_INET, usocket.SOCK_STREAM)
      client.connect(addr)
      client.settimeout(0)
      frame = sensor.snapshot()
      client.send(str(cframe.size()))
      client.send(cframe)
      client.close()
      服务器端
      import base64
      import threading
      from socket import *
      print("Waiting for connection...")
      phserv = socket(AF_INET,SOCK_STREAM)
      phserv.bind(('******', 20000))
      phserv.listen(5)
      car, addr = phserv.accept()
      print("Connected to")
      print(addr)
      a=car.recv(4)
      size=int(a.decode())
      time.sleep(1)
      fl=open('nw2.jpg','wb')
      while size>0:
              data = car.recv(1024)
              fl.write(data)
              size=size-len(data)
      time.sleep(0.02)
      fl.close()
      car.close()
