  • 请问在识别二维码的时候为何没有拍照也无法识别
    • ########### 模块引入 ##############
      from pyb import LED
      from pyb import UART,Timer
      from pyb import Pin
      ########## 变量定义 ##############
      class code_msg_to_send():
          quadrotor_is_to_start = 0
          pole_is_near = 0
      class code_msg_to_recieve():
          quadrotor_is_stopped = 1
      class receive(object):
          uart_buf = []
          _data_len = 0
          _data_cnt = 0
          state = 0
      ########## 基础配置 #############
      send_flag = code_msg_to_send()
      rec_flag = code_msg_to_recieve()
      R = receive()
      uart = UART(3,115200)#初始化串口 波特率 115200
      #sensor.set_vflip(True)
      #sensor.set_hmirror(True)
      sensor.set_framesize(sensor.QVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000.
      barcode_detected = 0
      qrcode_detected = 0
      barcode_pixels_threshold = [(49, 100, -20, 0, 16, 59)]    #条形码识别阈值
      qrcode_pixels_threshold = [600, 800]     #二维码识别阈值
      near_the_pole_threshold = [1000, 1500]   #到达杆识别阈值
      see_the_pole = False          #起飞后是否看见杆,通过线段拟合get_regression实现
      #BINARY_THRESHOLD = (208, 224)
      x_width = 80
      y_height = 60
      had_finished_barcode = 0
      had_finished_qrcode = 0
      ########### 串口 ##############
      # 串口数据解析
      def Receive_Anl(data_buf,num):
          #和校验
          sum = 0
          i = 0
          while i<(num-1):
              sum = sum + data_buf[i]
              i = i + 1
          sum = sum%256 #求余
          if sum != data_buf[num-1]:
              return
          #和校验通过
          #if data_buf[2]==0x01:
          #    print("receive 1 ok!")
          #if data_buf[2]==0x02:
          #   print("receive 2 ok!")
          if data_buf[2]==0xFD:     #控制字
              #接收各种标志
              rec_flag.quadrotor_is_stopped = data_buf[4]
              barcode_detected = data_buf[5]
              qrcode_detected = data_buf[6]
              #print("Recieve flags success!")
      # 串口通信协议接收
      def Receive_Prepare(data):
          if R.state==0:
              if data == 0xAA:#帧头
                  R.state = 1
                  R.uart_buf.append(data)
                  R.state = 0
          elif R.state==1:
              if data == 0xAF:#帧头
                  R.state = 2
                  R.state = 0
          elif R.state==2:
              if data <= 0xFF:#控制字
                  R.state = 3
                  R.state = 0
          elif R.state==3:#数据个数
              if data <= 33:
                  R.state = 4
                  R._data_len = data
                  R._data_cnt = 0
                  R.state = 0
          elif R.state==4:
              if R._data_len > 0:
                  R. _data_len = R._data_len - 1
                  if R._data_len == 0:
                      R.state = 5
                  R.state = 0
          elif R.state==5:
              R.state = 0
              Receive_Anl(R.uart_buf,R.uart_buf[3]+5)
              R.uart_buf=[]#清空缓冲区,准备下次接收数据
              R.state = 0
      # 读取串口缓存
      def uart_read_buf():
          i = 0
          buf_size = uart.any()
          while i<buf_size:
              Receive_Prepare(uart.readchar())
              i = i + 1
      # 标志位数据打包
      def pack_flag_data():
          pack_data=bytearray([0xAA,0xAF,0xF0,0x00,   #修改!!!!!!!!!!!
              send_flag.quadrotor_is_to_start,send_flag.pole_is_near,
              0x00,0x00,0x00,0x00,
              0x00,0x00])
          send_flag.quadrotor_is_to_start = 0
          #send_flag.pole_is_near = 0
          print("aaaa: ", send_flag.pole_is_near)
          lens = len(pack_data)#数据包大小
          pack_data[3] = lens-5;#有效数据个数
          i = 0
          sum = 0
          #和校验
          while i<(lens-1):
              sum = sum + pack_data[i]
              i = i+1
          pack_data[lens-1] = sum;
          return pack_data
      ############ 像素识别 ###########
      barcode_cnt = 0
      qrcode_cnt = 0
      pole_cnt = 0
      LED_ON = 0
      def count_pixels_with_movement(img):
          global x_width, y_height
          global barcode_detected, qrcode_detected
          global barcode_cnt, qrcode_cnt, pole_cnt
          global LED_ON
          blob = img.find_blobs(barcode_pixels_threshold, pixels_threshold=150, area_threshold=150, merge=True, margin=5)
          if blob:
              pass
              for i in blob:
                  img.draw_rectangle(i.rect(), color = 127)
                  barcode_detected = 1
                  LED_ON = 1
                  print("132123132131313131112311231")
                  print("aaaaaaaaaaaaaaaaaaaaaaaaaaaa")
                  return
              LED_ON = 0
              return
          x_pos = 0
          y_pos = 0
          total_white_pixels = 0
          for x_pos in range(x_width):
              for y_pos in range(y_height):
                  if img.get_pixel(x_pos, y_pos) == 255:
                      total_white_pixels += 1
          #print("total white pixels are", total_white_pixels)
      #    if total_white_pixels >= verticle_pixels_threshold[0] and \
      #            total_white_pixels <= verticle_pixels_threshold[1]:       #直角
      #        singleline_check.is_verticle = 2
      #    elif total_white_pixels >= track_line_pixels_threshold[0] and \
      #            total_white_pixels <= track_line_pixels_threshold[1]:     #巡线
      #        singleline_check.is_verticle = 1
          if total_white_pixels >= barcode_pixels_threshold[0] and \
                  total_white_pixels <= barcode_pixels_threshold[1]:        #条形码
             if barcode_cnt >= 0 and barcode_cnt <= 49:
                  barcode_cnt += 1
             if barcode_cnt == 50:
                  barcode_cnt = -1
          #        LED(1).toggle()  #红灯
          #        time.sleep(200)
          #        LED(1).toggle()
          #if total_white_pixels >= qrcode_pixels_threshold[0] and \
          #        total_white_pixels <= qrcode_pixels_threshold[1]:         #二维码
          #    if qrcode_cnt >= 0 and qrcode_cnt <= 49:
          #        qrcode_cnt += 1
          #    if qrcode_cnt == 50:
          #        qrcode_cnt = -1
          #        qrcode_detected = 1
          #        LED(3).toggle()   #蓝灯
          #        time.sleep(200)
          #        LED(3).toggle()
          #elif total_white_pixels >= near_the_pole_threshold[0] and \
          #        total_white_pixels <= near_the_pole_threshold[1]:         #到达杆
          #    if pole_cnt >= 0 and pole_cnt <= 49:
          #        pole_cnt += 1
          #    if pole_cnt == 50:
          #        pole_cnt = -1
          #        send_flag.pole_is_near = 1
          print("the flags are: %d %d %d"%(barcode_detected, qrcode_detected, send_flag.pole_is_near))
      ############ 拍照 ###############
      barcode_num = 0
      qrcode_num = 0
      # 拍摄照片
      def shot_images_while_tracking_lines():
          #global had_finished_barcode, had_finished_qrcode
          global barcode_detected, qrcode_detected, barcode_num, qrcode_num
          if barcode_detected: #and (not had_finished_barcode):
              #sensor.set_framesize(sensor.QVGA)
              #barcode_detected = 0
              if barcode_num <= 3:
                  barcode_num += 1
                  barcode_name = "barcode_" + str(barcode_num)
                  sensor.snapshot().save(barcode_name + ".jpg")
                  print(barcode_name + ".jpg is saved!")
                  time.sleep(5)
                  if barcode_num >= 3:
                      barcode_num = 0
                      print("bar:", barcode_detected)
                      #had_finished_barcode = 1
                      return True
          if qrcode_detected: #and (not had_finished_qrcode):
              #qrcode_detected = 0
              if qrcode_num <= 4:
                  qrcode_num += 1
                  qrcode_name = "qrcode_" + str(qrcode_num)
                  sensor.snapshot().save(qrcode_name + ".jpg")
                  print(qrcode_name + ".jpg is saved!")
                  time.sleep(5)
                  if qrcode_num >= 3:
                      qrcode_num = 0
                      print("qr:", qrcode_detected)
                      #had_finished_qrcode = 1
                      return True
      pin2 = Pin('P2', Pin.OUT_PP, Pin.PULL_NONE)
      ############# 主函数 #########
          img = sensor.snapshot()#.binary([BINARY_THRESHOLD])
          #uart_read_buf()
          print(send_flag.quadrotor_is_to_start)
          if not send_flag.quadrotor_is_to_start:
              print(rec_flag.quadrotor_is_stopped)
              if rec_flag.quadrotor_is_stopped:
                  #rec_flag.quadrotor_is_stopped = 0
                  #shot_images_while_tracking_lines()
                  #send_flag.quadrotor_is_to_start = 1
                  print("ok!")
                  uart.write(pack_flag_data())
          if send_flag.pole_is_near:
              LED(1).off()
              LED(3).off()
              LED(4).off()
              LED(3).on()   #?
              #time.sleep(20)
          if LED_ON:
              #LED_ON = 0
              #lock_flag = 1
              LED(1).off()
              LED(2).off()
              LED(3).off()
              LED(4).off()
              shot_images_while_tracking_lines()   #?
              LED(2).on()
              pin2.value(1)    # 点灯
              sensor.skip_frames(time = 200)
              LED(2).off()
              pin2.value(0)
          if qrcode_detected:
              qrcode_detected = 0
              LED(1).off()
              LED(3).off()
              LED(4).off()
              LED(1).toggle()   #?
      ```运行上述代码后,可以条形码部分的识别和拍照可以进行,但是二维码部分既无法识别也拍照不了,求大神帮我看看这是啥情况,谢谢
