  • 为啥用openmv识别人脸的准确度那么低????
    • import sensor, image, time,pyb
      from pyb import Servo
      pan_servo=Servo(1)#p7
      tilt_servo=Servo(2)#tilt倾斜p8
      red_threshold  = (13, 49, 18, 61, 6, 47)#threshold  yuzhi
      #pan_pid = PID(p=0.07, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
      #tilt_pid = PID(p=0.05, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
      pan_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID
      tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID
      # Sensor settings
      # HQVGA and GRAYSCALE are the best for face tracking.
      sensor.set_vflip(True)#镜像翻转
      sensor.skip_frames(10)
          if  objects:
              max_blob = find_max( objects)
              img.draw_cross(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/2))
              #sensor.skip_frames(time = 5000)
              NUM_SUBJECTS = 2#图像库中不同人数,一共6人
              NUM_SUBJECTS_IMGS = 50 #每人有20张样本图片
              # 拍摄当前人脸。image.save(path[, roi[, quality=50]])
              img = sensor.snapshot()#.save("singtown/snapshot-%d.pgm" % pyb.rng())
              img = img.draw_rectangle(max_blob).save("singtown/snapshot-%d.pgm" % pyb.rng(),[max_blob[0],max_blob[1],max_blob[2],max_blob[3]])
              #d0为当前人脸的lbp特征
              imge = None
              pmin = 999999
              num=0
              def min(pmin, a, x):
                  global num
                  if a<pmin:
                      pmin=a
                      num=x
                  return pmin
                  dist = 0
                      imge = image.Image("singtown/s%d/%d.pgm"%(s, i))
                      d1 = imge.find_lbp((0, 0, imge.width(), imge.height()))
                      #d1为第s文件夹中的第i张图片的lbp特征
              if pmin>31062:
                   img.draw_string(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/2),"stranger",[0,0,0],scale=2, mono_space=False).save("singtown/stranger-%d.jpg" % pyb.rng())
                  # break
              elif  num ==1:
                      img.draw_string(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/2),"man",[0,0,0],scale=2, mono_space=False).save("singtown/1-%d.jpg" % pyb.rng())
              elif num==2:
                      img.draw_string(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/2),"woman",[0,0,0],scale=2, mono_space=False).save("singtown/2-%d.jpg" % pyb.rng())
             # elif num==3:
              #        img.draw_string(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/2),"ghx",[0,0,0],scale=2, mono_space=False).save("singtown/mb-%d.jpg" % pyb.rng())
                 # print(pmin)
              print(num) # num为当前最匹配的人的编号。
             # image.draw_string(x, y, text[, color[, scale=1[, x_spacing=0[, y_spacing=0[, mono_space=True]]]]])
