  • 这个怎魔改才能把这个测距功能通过WiFi拓展版让手机能看见
    • import sensor, image, time, network, usocket, sys
      SSID ='lll'
      KEY ='1234567890'
      HOST =''
      PORT =8080
      yellow_threshold   = (14, 82, 11, 116, 46, -21)
      sensor.reset()# Initialize the camera sensor.
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      #您可以阻止等待客户端连接
      def start_streaming(s):
          client, addr = s.accept()
          # 将客户端套接字超时设置为2秒
          client.settimeout(2.0)
      K=1300#the value should be measured
          if len(blobs) == 1:
              b = blobs[0]
              Lm = (b[2]+b[3])/2
              c = K/Lm
              img.draw_string(10,10, str(c))
              print(c)
