NameError;name'RGB565'is not defined
SNHK4.png 图片地址)
不知道为什么会出现这种问题。。。新人求教,源代码如下
import sensor,image,timered_threshold_01=(0,35,0,50,-10,40)
sensor.set_pixformat(sensor,RGB565)
sensor,skip_frames(10)
sensor.set_auto_whitebal(False)clock=time.clock()
while(True):clock.tick() img=sensor.snapshot() blobs=img.find_blobs([red_threshold_01],area_threshold=150) if blobs: print(blobs) for b in blobs: img.draw_rectangle(b[0:4]) img.draw_cross(b[5],b[6]) print(clock.fps())
是sensor.RGB565
中间是 点 而不是 逗号
