星瞳实验室APP,快速收到回复
  • 代码整合问题,如何将人脸识别和人脸追踪的代码整合到一起?人脸的代码也不知道对不对?大佬求助
    • 这个是人脸追踪代码
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      red_threshold = (13, 49, 18, 61, 6, 47)
          img.draw_cross (int(max_blob[0]+max_blob[2]/2), int(max_blob[1]+max_blob[3]/2)) # cx, cy
      这个是人脸识别代码
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      sensor.skip_frames(time = 500)
      NUM_SUBJECT = 6
      NUM_SUBJECT_IMGS = 10
      imgs = sensor.snapshot()
      d0 = imgs.find_lbp((0,0,imgs.width(),imgs.height()))
      def min(pmin,a,s):
      global num
      if a<pmin:
      pmin=a
      num=s
      return pmin
      imgs = None
      pmin = 999999
      num=0
      while():
          for s in range(2,NUM_SUBJECT+1):
                  dist = 0
                  for i in range(2,NUM_SUBJECT+1):
                      imgs = image.Image("singtown/s%d/%d.pmg"%(s,i))
                      d1 = imgs.find_lbp((0,0,imgs.width(),imgs.height()))
                      dist +=image.match_descriptor(d0,d1)
                  pmin = min(pmin.dist/NUM_SUBJECTS_IMGS,s)
          if pmin<7000:
              print("wellcome!")
          print("检测到陌生人")
          print("未检测到人脸")
