目的是用特征的方法使云台跟随目标转动;并且发送目标的坐标值; 编译没问题;但是运行不行;除了发送坐标值可以,其他都不好;
from pyb import Servo
pan_servo=Servo(1)
tilt_servo=Servo(2)pan_pid = PID(p=0.07, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
sensor.set_contrast(3)
sensor.set_gainceiling(16)sensor.set_framesize(sensor.QVGA) # use QQVGA for speed.
#ensor.skip_frames(10) # Let new settings take affect.
#sensor.set_auto_whitebal(False) # turn this off.sensor.skip_frames(time = 2000)
sensor.set_auto_gain(False, value=100)clock = time.clock() # Tracks FPS.
uart=UART(3,115200,timeout_char=10)
if kpts:
print(kpts)
img.draw_keypoints(kpts)
time.sleep(1)kpts1 = None
img = sensor.snapshot() # Take a picture and return the image.if (kpts1 == None): kpts1 = img.find_keypoints([106,68,125,87],max_keypoints=150, threshold=10, scale_factor=1.2) draw_keypoints(img, kpts1) else: kpts2 = img.find_keypoints([106,68,125,87],max_keypoints=150, threshold=10, normalized=True) if (kpts2): match = image.match_descriptor(kpts1, kpts2, threshold=85) if (match.count()>10): img.draw_rectangle(match.rect()) img.draw_cross(match.cx(), match.cy(), size=10) pan_error = match.cx()-img.width()/2 tilt_error = match.cy()-img.height()/2 pan_output=pan_pid.get_pid(pan_error,1)/2 tilt_output=tilt_pid.get_pid(tilt_error,1) print("pan_output",pan_output) pan_servo.angle(pan_servo.angle()+pan_output) tilt_servo.angle(tilt_servo.angle()-tilt_output) output_str="[%d,%d]" % (match.cx(),match.cy()) #方式1 #output_str=json.dumps([max_blob.cx(),max_blob.cy()]) #方式2 print('you send:',output_str) uart.write(output_str+'\r\n')
以上是代码,目的是用特征的方法使云台跟随目标转动;并且发送目标的坐标值;
