  • 代码能实现什么功能 在线等
    • MJPEG Streaming AP.
      这个例子展示了如何在AccessPoint模式下进行MJPEG流式传输。
      Android上的Chrome,Firefox和MJpegViewer App已经过测试。
      连接到OPENMV_AP并使用此URL:http://192.168.1.1:8080查看流。
      import sensor, image, time, network, usocket, sys, mjpeg, pyb
      RED_LED_PIN = 1
      BLUE_LED_PIN = 3
      Reset sensor
      Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      在AP模式下启动wlan模块。
      #您可以阻止等待客户端连接
      def start_streaming(s):
      client, addr = s.accept()
      # 将客户端套接字超时设置为2秒
      client.settimeout(2.0)
      # 从客户端读取请求
      data = client.recv(1024)
      # 应该在这里解析客户端请求
      # 发送多部分head
                  "Server: OpenMV\r\n" \
                  "Pragma: no-cache\r\n\r\n")
      # FPS clock
      # 开始流媒体图像
      #注:禁用IDE预览以增加流式FPS。
          frame = sensor.snapshot()
          header = "\r\n--openmv\r\n" \
          client.send(header)
          client.send(cframe)
      # 创建服务器套接字
      # Bind and listen
      s.bind([HOST, PORT])
      s.listen(5)
          # 设置服务器套接字超时
          # 关闭并重新打开。在这里使用超时关闭并重新创建套接字。
          s.settimeout(3)
          start_streaming(s)
      except OSError as e:
          s.close()
          print("socket error: ", e)
          #sys.print_exception(e)
      pyb.LED(RED_LED_PIN).on()
      print("About to start detecting faces...")
      sensor.skip_frames(time = 2000) # Give the user time to get ready.
      pyb.LED(RED_LED_PIN).off()
      print("Now detecting faces!")
      pyb.LED(BLUE_LED_PIN).on()
      diff = 10 # We'll say we detected a face after 10 frames.
      while(diff):
          faces = img.find_features(face_cascade, threshold=0.5, scale_factor=1.5)
          if faces:
              diff -= 1
              for r in faces:
                  img.draw_rectangle(r)
      m = mjpeg.Mjpeg("example-%d.mjpeg" % pyb.rng())
      print("You're on camera!")
      for i in range(200):
      m.close(clock.fps())
      pyb.LED(BLUE_LED_PIN).off()
      print("Restarting...")
