  • 我想发送四个数据,但是只能接收两个,如何增加arduino接受openmv发送的数据
    • OPENMV代码:
      yellow_threshold   = ( 46,  100,  -68,   72,   58,   92)
          blobs = img.find_blobs([yellow_threshold],area_threshold=3000)
              data=[]
              img.draw_rectangle(max_blob[0:4])
              data.append((max_blob[5], max_blob[6],max_blob[2],max_blob[3]))
              #{(1,22),(-3,33),(22222,0),(9999,12),(0,0)}
              data_out = json.dumps(set(data))
              uart.write(data_out +'\n')
              print('you send:',data_out)
              print("not found!")
      ARDUINNO代码
      #include <SoftwareSerial.h>
      SoftwareSerial softSerial(10, 11); // RX, TX
      typedef struct
        int data[50][3] = {{0,0,0}};
        int len = 0;
      }List;
      List list;
      void setup() {
        // put your setup code here, to run once:
        softSerial.begin(115200);
      void loop() {
        if(softSerial.available())
          getList();
          for (int i=0; i<list.len; i++)
            Serial.print(list.data[i][0]);
            Serial.print('\t');
            Serial.println(list.data[i][1]);
            Serial.print('\n');
            Serial.println(list.data[i][2]);
            Serial.print('\t');
            Serial.println(list.data[i][3]);
          Serial.println("============");
          clearList();
      String detectString()
        while(softSerial.read() != '{');
        return(softSerial.readStringUntil('}'));
      void clearList()
        memset(list.data, sizeof(list.data),0);
        list.len = 0;
      void getList()
        String s = detectString();
        String numStr = "";
        for(int i = 0; i<s.length(); i++)
          if(s[i]=='('){
            numStr = "";
          else if(s[i] == ','){
            list.data[list.len][0] = numStr.toInt();
            list.data[list.len][1] = numStr.toInt();
            list.data[list.len][2] = numStr.toInt();
            numStr = "";
          else if(s[i]==')'){
            list.data[list.len][3] = numStr.toInt();
            numStr = "";
            list.len++;
          else{
            numStr += s[i];
