固件是最新的
# 鲁棒线性回归例程
# 可以跟踪所有指向相同的总方向但实际上没有连接的线。 在线路上使用
# find_blobs(),以便更好地过滤选项和控制。
rho_pid = PID(p=6.0, i=0.1, d=0.3) #控制rol
theta_pid = PID(p=2.5, i=0)#控制yaw
finds_blob=0
flymode=1
THRESHOLD = (0, 100) # Grayscale threshold for dark things...
BINARY_VISIBLE = True # 首先二值化
up_roi = (0,0, 80, 15)
down_roi = (0, 55, 80, 15)
left_roi = (0, 0, 25, 60)
righ_roi = (55, 0,25, 40)
y=0
up_roif = (0,0, 80, 30)
down_roif = (0, 30, 80, 30)
left_roif = (0, 0, 40, 60)
righ_roif = (40, 0,40, 60)
#阈值内数据(白色像素)较多时,QQVGA帧率降到5以下。线较细时可以使用(7·19测试)
#QQQVGA较稳定,帧率保持高速(50以上)
clock = time.clock() # to process a frame sometimes.
sensor.set_vflip(True)
sensor.set_hmirror(True)
def find_border(img,area_roi):
area=0
singleline_check = img.get_regression([(255,255)],roi=area_roi, robust = True)
if (singleline_check):
area=1
return area
uart = UART(3,500000)#初始化串口 波特率 500000
class Receive(object):
uart_buf = []
_data_len = 0
_data_cnt = 0
state = 0
R=Receive()
def UartSendData(Data):
uart.write(Data)
def DotDataPack(color,flag,x,y):
print("found: x=",x," y=",y, flymode)
pack_data=bytearray([0xAA,0x29,0x05,0x41,0x00,color,flag,x>>8,x,(y)>>8,(y),0x00])
lens = len(pack_data)#数据包大小
pack_data[4] = 6;#有效数据个数
i = 0
sum = 0
#和校验
while i<(lens-1):
sum = sum + pack_data[i]
i = i+1
pack_data[lens-1] = sum;
return pack_data
times=0
def find_123(img):
global times
global flymode
upflag=0
leftflag=0
rightflag=0
downflag=0
finds_blob=0
upflag=find_border(img,up_roi)
downflag=find_border(img,down_roi)
leftflag=find_border(img,left_roi)
rightflag=find_border(img,righ_roi)
if upflag:
finds_blob=finds_blob|0x01
if downflag:
finds_blob=finds_blob|0x02
if leftflag:
finds_blob=finds_blob|0x04
if rightflag:
finds_blob=finds_blob|0x08
if flymode==1 :
if finds_blob&0x01==0x00:
times+=1
else :
times=0
if times>10:
if finds_blob&0x04!=0x00:
flymode=3
elif finds_blob&0x08!=0x00:
flymode=4
elif flymode==2 :
if finds_blob&0x02==0x00:
times+=1
if times>15:
flymode=3
flymode=4
else :
times=0
elif flymode==3 :
if finds_blob&0x04==0x00:
times+=1
if times>15:
if finds_blob&0x01!=0x00:
flymode=1
elif finds_blob&0x02!=0x00:
flymode=2
else :
times=0
elif flymode==4 :
if finds_blob&0x08==0x00:
times+=1
if times>15:
flymode=1
flymode=2
else :
times=0
img = sensor.snapshot().binary([(0,100)]).lens_corr(strength = 1.8, zoom = 1.0)# if BINARY_VISIBLE else sensor.snapshot()
#for i in [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30]:
#img[i*160:i*160+80]=255
#print(img[0])
# 返回类似于由find_lines()和find_line_segments()返回的线对象。
# 你有x1(),y1(),x2(),y2(),length(),
# theta()(以度为单位的旋转),rho()和magnitude()。
# magnitude() 表示线性回归的工作情况。这对于鲁棒的线性回归意味着不同
# 的东西。一般来说,值越大越好...
# for l in img.find_lines(roi=(30,20,20,20),threshold=1000)
find_123(img)
#print(flymode)
if flymode==1 :
roi=up_roif
elif flymode==2 :
roi=down_roif
elif flymode==3 :
roi=left_roif
elif flymdoe==4 :
roi=righ_roif
line = img.get_regression([(255,255) if BINARY_VISIBLE else THRESHOLD],roi=roi,robust = True)
#line = img.get_regression([(255,255) if BINARY_VISIBLE else THRESHOLD],robust = True)
if (line):
if line.theta()>90:
theta_err = line.theta()-180
if line.magnitude()>8:
rho_output = rho_pid.get_pid(rho_err,1) #正值->右移 rol
theta_output = theta_pid.get_pid(theta_err,1) #正值->右转 yaw
#if abs(theta_output)>80:
#y=0
#else :
# y=200
if(flymode==1):
x=rho_output
y=100
elif(flymode==2):
x=rho_output
y=-100
elif(flymode==3):
x=-100
y=rho_output
elif(flymode==4):
x=100
y=rho_output
UartSendData(DotDataPack(0,1,int(x),int(y)))
#print("rho_output="+str(rho_output)+" theta_output="+str(theta_output))
img.draw_line(line.line(), color = 127,thickness=2)
print("FPS %f, mag = %s" % (clock.fps(), str(line.magnitude()) if (line) else "N/A"))
