  • 我想给Arduino发送红色色块的一个坐标信息,在Arduino那边串口监视器显示的是乱码
      red_threshold = (30, 100, 15, 127, 15, 127)
      sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed.分辨率为120*160。
      if blob[2]*blob[3]>max_size:
      max_size=blob[2]*blob[3]
      img.draw_cross(int(img.width()/2),int(img.height()/2))
      #print('sum : %d'% len(blobs))
          #{(1,22),(-3,33),(22222,0),(9999,12),(0,0)}
        uart.writechar((max_blob[5]))
       # print('you send:',data_out)
        print(max_blob[5], max_blob[6])
        print(img.width()/2,img.height()/2)#宽度80,高度60
        print("not found!")
      Arduino
      #include <SoftwareSerial.h>
      SoftwareSerial softSerial(10, 11); // RX, TX
      char c;
      String comdata = "";
      void setup() {
      // put your setup code here, to run once:
      softSerial.begin(115200);
      void loop() {
      if(softSerial.available())
      {comdata += char(softSerial.read());
      delay(2);
      Serial.println(comdata);
