  • 定时器问题,导致程序运行时突然卡死,为什么?
      from pyb import Pin, Timer
      #初始化摄像头,reset()是sensor模块里面的函数
      #设置图像像素大小,sensor.QQVGA: 160x120,sensor.QQVGA2: 128x160 (一般用于LCD
      #扩展板),sensor.QVGA: 320x240,sensor.VGA: 640x480, sensor.QQCIF: 88x72,sensor.QCIF: 176x144,sensor.CIF: 352x288
      sensor.skip_frames(time = 2000) # Wait for settings take effect.
      def tick(timer): # we will receive the timer object when being called
      print("Timer callback")
      tim = Timer(4, freq=1) # create a timer object using timer 4 - trigger at 1Hz
      tim.callback(tick) # set the callback to our tick function
      #截取当前图像,存放于变量img中。注意python中的变量是动态类型,不需要声明定义,直接用即可。
      #print(clock.fps())
      请在这里粘贴代码
