OpenMV与Arduino通信的问题
这是OpenMV的代码
import sensor, image, time import json from pyb import UART # For color tracking to work really well you should ideally be in a very, very, # very, controlled enviroment where the lighting is constant... yellow_threshold = ( 46, 100, -68, 72, 58, 92) # You may need to tweak the above settings for tracking green things... # Select an area in the Framebuffer to copy the color settings. sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_whitebal(False) # turn this off. clock = time.clock() # Tracks FPS. uart = UART(3, 115200) while(True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([yellow_threshold]) if blobs: #print('sum : %d'% len(blobs)) data=[] for b in blobs: # Draw a rect around the blob. img.draw_rectangle(b.rect()) # rect img.draw_cross(b.cx(), b.cy()) # cx, cy data.append((b.cx(),b.cy())) #{(1,22),(-3,33),(22222,0),(9999,12),(0,0)} data_out = json.dumps(set(data)) uart.write(data_out +'\n') print('you send:',data_out) else: print("not found!")
这是Arduino的代码
#include <SoftwareSerial.h> SoftwareSerial softSerial(10, 11); // RX, TX typedef struct { int data[50][2] = {{0,0}}; int len = 0; }List; List list; void setup() { // put your setup code here, to run once: softSerial.begin(115200); Serial.begin(115200); } void loop() { if(softSerial.available()) { getList(); for (int i=0; i<list.len; i++) { Serial.print(list.data[i][0]); Serial.print('\t'); Serial.println(list.data[i][1]); } Serial.println("============"); clearList(); } } String detectString() { while(softSerial.read() != '{'); return(softSerial.readStringUntil('}')); } void clearList() { memset(list.data, sizeof(list.data),0); list.len = 0; } void getList() { String s = detectString(); String numStr = ""; for(int i = 0; i<s.length(); i++) { if(s[i]=='('){ numStr = ""; } else if(s[i] == ','){ list.data[list.len][0] = numStr.toInt(); numStr = ""; } else if(s[i]==')'){ list.data[list.len][1] = numStr.toInt(); numStr = ""; list.len++; } else{ numStr += s[i]; } } }
这是输出的截图
为什么Arduino串口监控器里的信息有的会出现0呢?
