  • 识别模版并闪光
    • 识别模版并闪光 目前常量求解决方案
      Template Matching Example - Normalized Cross Correlation (NCC)
      This example shows off how to use the NCC feature of your OpenMV Cam to match
      image patches to parts of an image... expect for extremely controlled enviorments
      NCC is not all to useful.
      WARNING: NCC supports needs to be reworked! As of right now this feature needs
      a lot of work to be made into somethin useful. This script will reamin to show
      that the functionality exists, but, in its current state is inadequate.
      import time, sensor, image,pyb
      Reset sensor
      Set sensor settings
      Max resolution for template matching with SEARCH_EX is QQVGA
      You can set windowing to reduce the search image.
      Load template.
      Template should be a small (eg. 32x32 pixels) grayscale image.
      template = image.Image("/sb1.pgm")
      Run template matching
      led = pyb.LED(3) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
      usb = pyb.USB_VCP()
      led.on()
      time.sleep(150)
      led.off()
      time.sleep(100)
      led.on()
      time.sleep(150)
      led.off()
      time.sleep(600)
      if r:
          img.draw_rectangle(r)
    • 闪光是什么意思?请具体描述一下问题。
