  • OPENMV 返回信息中有​​Homography矩阵​​相关信息?若没有该怎么构建​​Homography矩阵?
    • 详细描述问题:
      1、运行的是哪一个程序?
      2、运行程序时出现了什么问题?
      3、想解决的问题
    • @uzbd
      -- coding: utf-8 --
      初始化摄像头
      sensor.skip_frames(time=1000)
      sensor.set_auto_gain(False)
      相机内参设置
      f_x = (2.8 / 3.6736) * 640
      f_y = (2.8 / 2.7384) * 480
      c_x = 640 * 0.5
      c_y = 480 * 0.5
      系统状态变量
      SETTING_BASE = 0
      MONITORING = 1
      MEASURING = 2
      system_state = SETTING_BASE
      位置信息
      base_position = None # 存储基准位置(中心点)
      filtered_position = None
      stroke_mm = 0
      base_samples = []
      current_samples = []
      INITIAL_SAMPLES = 20
      CURRENT_SAMPLES = 20
      运动检测参数
      MOTION_THRESHOLD = 20
      STABLE_FRAMES = 50
      stable_count = 0
      last_img = None
      roi = (0, 0, 0, 0)
      roi1 = (0, 0, 250, 480) # 运动检测的ROI区域
      AprilTag参数
      K1=14.98
      TAG_SIZE_MM = 26
      TAG_AREA_MM2 = TAG_SIZE_MM * TAG_SIZE_MM # 标签实际面积
      x0, y0, x1, y1 = None, None, None, None
      计算Open MV到TAG的距离
      def Tag_OpenMV_distance(tx,ty,tz):
      Distance1 = K1 * math.sqrt(txtx+tyty+tz*tz)
      return Distance1
      计算实际距离的函数
      def calculate_real_distance(pixel_distance, k_value):
      return pixel_distance * k_value
      计算二维空间欧氏距离
      def euclidean_distance(pos1, pos2):
      if pos1 is None or pos2 is None:
      return 0.0
      dx = pos1[0] - pos2[0]
      dy = pos1[1] - pos2[1]
      return math.sqrt(dxdx + dydy)
      卡尔曼滤波器类
      class KalmanFilter:
      def init(self, initial_value, process_variance=1, measurement_variance=0.5):
      一维卡尔曼滤波器
      :param initial_value: 初始估计值
      :param process_variance: 过程噪声方差 (Q)
      小值 (1e-6 到 1e-4): 状态变化缓慢,滤波器更"保守"
      大值 (0.1 到 1.0): 状态变化快速,滤波器响应更快
      :param measurement_variance: 测量噪声方差 (R)
      小值 (0.01 到 0.1): 测量值可靠,滤波器更信任测量
      大值 (1.0 到 10.0): 测量值噪声大,滤波器更信任预测
      :estimate_variance: 初始估计方差 (P)
      表示初始状态的不确定性
      中等不确定性设为1
      高不确定性可设10-100
      self.state_estimate = initial_value
      self.estimate_variance = 20 # 初始估计方差 (P)
      self.process_variance = process_variance
      self.measurement_variance = measurement_variance
      def update(self, measurement):
          prior_estimate = self.state_estimate
          prior_variance = self.estimate_variance + self.process_variance
          kalman_gain = prior_variance / (prior_variance + self.measurement_variance)
          self.state_estimate = prior_estimate + kalman_gain * (measurement - prior_estimate)
          self.estimate_variance = (1 - kalman_gain) * prior_variance
          return self.state_estimate
      创建卡尔曼滤波器实例
      为四个角点创建滤波器 (每个角点有x,y坐标)
      corner_kalman = []
      for i in range(4): # 四个角点
      corner_kalman.append([
      KalmanFilter(initial_value=320.0), # x坐标滤波器
      KalmanFilter(initial_value=240.0)]) # y坐标滤波器
      中心点卡尔曼滤波器
      center_x_kalman = KalmanFilter(initial_value=320.0)
      center_y_kalman = KalmanFilter(initial_value=240.0)
      边平均长度卡尔曼滤波器
      edge_kalman = KalmanFilter(initial_value=50.0)
      面积卡尔曼滤波器
      area_kalman = KalmanFilter(initial_value=1000.0)
      加权平均位置计算
      def weighted_average_position(positions):
      if not positions:
      return None
      #n = len(positions)
      total_weight = 0
      weighted_x = 0
      weighted_y = 0
      for i, pos in enumerate(positions):
      weight = i + 1
      total_weight += weight
      weighted_x += pos[0] * weight
      weighted_y += pos[1] * weight
      return (weighted_x / total_weight, weighted_y / total_weight)
      运动检测函数
      def detect_motion(current_img):
      global last_img, stable_count
      if last_img is None:
      last_img = current_img.copy()
      return True
      diff = current_img.copy(roi=roi).difference(last_img.copy(roi=roi))
      stats = diff.get_statistics()
      avg_change = (stats.l_max() - stats.l_min()) / 2
      if avg_change > MOTION_THRESHOLD:
      stable_count = 0
      return True
      stable_count += 1
      return False
      ================ 三重尺寸计算方法 ================
      def calculate_edge_lengths(corners):
      计算四条边的长度
      edges = []
      n = len(corners)
      for i in range(n):
      j = (i + 1) % n
      dx = corners[j][0] - corners[i][0]
      dy = corners[j][1] - corners[i][1]
      edges.append(math.sqrt(dxdx + dydy))
      return edges
      def calculate_area(corners):
      使用鞋带公式计算多边形面积
      n = len(corners)
      area = 0.0
      for i in range(n):
      j = (i + 1) % n
      area += corners[i][0] * corners[j][1]
      area -= corners[j][0] * corners[i][1]
      return abs(area) / 2.0
      def filter_corners(corners):
      对四个角点应用卡尔曼滤波
      filtered_corners = []
      for i in range(4):
      x = corner_kalman[i][0].update(corners[i][0])
      y = corner_kalman[i][1].update(corners[i][1])
      filtered_corners.append((x, y))
      return filtered_corners
      def calculate_center(corners):
      计算四个角点的中心
      x_sum = sum(corner[0] for corner in corners)
      y_sum = sum(corner[1] for corner in corners)
      return (x_sum / 4, y_sum / 4)
      def calculate_combined_size(filtered_corners):
      三重尺寸计算方法:
      1. 计算四条边的平均长度
      2. 使用鞋带公式计算面积
      3. 从面积推导等效边长
      4. 加权组合 (30% 边平均 + 20% 面积等效 + 50%TAG返回的像素宽度与高度的平均值)
      # 计算四条边长度
      edges = calculate_edge_lengths(filtered_corners)
      avg_edge = sum(edges) / len(edges)
      # 计算面积
      area = calculate_area(filtered_corners)
      # 计算等效边长 (假设为正方形)
      equiv_edge = math.sqrt(area)
      # 加权组合
      combined_size = 0.3 * avg_edge + 0.2 * equiv_edge + 0.5 * tag.h-1#((tag.h+tag.w)/2)
      return combined_size, avg_edge, equiv_edge, area
      ================ 三重尺寸计算方法结束 ================
      主循环
      img = sensor.snapshot().lens_corr(1.6)
      if system_state == SETTING_BASE:
          tags = img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y,
                  families=image.TAG36H11, tag_size=TAG_SIZE_MM)
          img.draw_rectangle(roi1, color=(255, 0, 0))
          if tags:
              tag = tags[0]
              # 检查标签质心是否在ROI1区域内
              tag_in_roi = (roi1[0] <= tag.cxf <= roi1[0] + roi1[2] and
                              roi1[1] <= tag.cyf <= roi1[1] + roi1[3])
              if not tag_in_roi:
              # 标签不在ROI1区域内,显示提示信息
                  img.draw_string(0, 10, "Move tag to ROI1 area !!!", color=(255, 255, 0))
                  continue  # 跳过后续处理
              tx,ty,tz=tag.x_translation,tag.y_translation,tag.z_translation
              x0 , y0 = tag.cxf , tag.cyf
              # 获取原始角点
              raw_corners = tag.corners
              # 对角点进行卡尔曼滤波
              filtered_corners = filter_corners(raw_corners)
              # 计算滤波后的中心点
              center_x, center_y = calculate_center(filtered_corners)
              # 对TAG质心进行卡尔曼滤波
              #filtered_center_x = center_x_kalman.update(tag.cxf)
              #filtered_center_y = center_y_kalman.update(tag.cyf)
              # 对中心点进行卡尔曼滤波
              filtered_center_x = center_x_kalman.update(center_x)
              filtered_center_y = center_y_kalman.update(center_y)
              # 使用双重尺寸计算方法
              #combined_size, avg_edge, equiv_edge, area = calculate_combined_size(filtered_corners)
              # 对平均边和面积进行卡尔曼滤波
              #filtered_avg_edge = edge_kalman.update(avg_edge)
              #filtered_area = area_kalman.update(area)
              # 重新计算组合尺寸(使用滤波后的值)
              #combined_size = 0.7 * filtered_avg_edge + 0.3 * math.sqrt(filtered_area)#+0.4 *((tag.h+tag.w)/2)
              # 绘制标签轮廓和角点
              for i in range(4):
                  # 绘制滤波后的角点
                  img.draw_circle(int(filtered_corners[i][0]), int(filtered_corners[i][1]), 5, color=(0, 255, 255))
                  # 绘制原始角点
                  img.draw_circle(int(raw_corners[i][0]), int(raw_corners[i][1]), 3, color=(255, 0, 255))
                  # 绘制边
                  next_i = (i + 1) % 4
                  img.draw_line(
                      int(filtered_corners[next_i][0]), int(filtered_corners[next_i][1]),
                      color=(0, 255, 0)
              # 绘制滤波后的中心点
              img.draw_cross(int(filtered_center_x), int(filtered_center_y), color=(0, 255, 0), size=10)
              # 显示尺寸信息
              img.draw_string(0, 400, "ID:%d" % tag.id, color=(255, 0, 0))
              #img.draw_string(0, 370, "AvgEdge:%.1f" % filtered_avg_edge, color=(255, 0, 0))
              #img.draw_string(0, 390, "EquivEdge:%.1f" % math.sqrt(filtered_area), color=(0, 255, 0))
              #img.draw_string(0, 380, "Combined:%.1f" % combined_size, color=(0, 255, 255))
              #img.draw_string(0, 360, "Area:%.1f" % filtered_area, color=(255, 255, 0))
              img.draw_string(0, 350, "H:%d" % tag.rect[3], color=(255, 255, 0))
              img.draw_string(0, 340, "W:%d" % tag.rect[2], color=(255, 255, 0))
              # 记录滤波后的中心位置
              current_position = (filtered_center_x, filtered_center_y)
              base_samples.append(current_position)
              progress = len(base_samples) / INITIAL_SAMPLES * 100
              img.draw_string(0, 10, "Setting base:%d%%" % progress, color=(255, 255, 0))
              if len(base_samples) >= INITIAL_SAMPLES:
                  # 计算加权平均位置
                  base_position = weighted_average_position(base_samples)
                  print("Base position set: (%.1f, %.1f)" % base_position)
                  img.draw_string(0, 420, "The base position is set!", color=(255, 0, 0))
                  system_state = MONITORING
                  roi = (0, tag.rect[1]-20, 640, tag.rect[2]+40)  # 运动检测的ROI区域
                  base_samples = []
              img.draw_string(0, 10, "Place piston at base position", color=(255, 0, 0))
      elif system_state == MONITORING:
          motion_detected = detect_motion(img)
          status = "In motion" if motion_detected else "In stability (%d/%d)" % (stable_count, STABLE_FRAMES)
          img.draw_rectangle(roi, color=(0, 255, 0))
          img.draw_string(0, 10, "State: %s" % status, color=(255, 255, 0))
          if stable_count >= STABLE_FRAMES:
              print("活塞已停止,开始最终定位")
              img.draw_string(0, 20, "The piston has stopped and begins final positioning!", color=(255, 0, 0))
              system_state = MEASURING
      elif system_state == MEASURING:
          if tags:
              tag = tags[0]
              x1 , y1 = tag.cxf , tag.cyf
              # 获取原始角点
              # 对角点进行卡尔曼滤波
              # 计算滤波后的中心点
              # 对中心点进行卡尔曼滤波
              # 使用双重尺寸计算方法
              # 对平均边和面积进行卡尔曼滤波
              # 重新计算组合尺寸(使用滤波后的值)
              combined_size = 0.3 * filtered_avg_edge + 0.2 * math.sqrt(filtered_area)+0.5 *  tag.h-1#((tag.h+tag.w)/2)
              # 计算比例系数
              k_value = TAG_SIZE_MM / combined_size
              # 绘制标签轮廓和角点
              for i in range(4):
                  # 绘制滤波后的角点
                  # 绘制原始角点
                  # 绘制边
                  img.draw_line(
                      color=(0, 255, 0)
              # 绘制滤波后的中心点
              # 显示尺寸信息
              # 记录滤波后的中心位置
              current_samples.append(current_position)
              # 保持采样列表长度
              if len(current_samples) > CURRENT_SAMPLES:
                   current_samples.pop(0)
              # 计算加权平均位置
              if current_samples:
                  avg_x, avg_y = weighted_average_position(current_samples)
                  # 计算像素距离
                  pixel_distance = euclidean_distance((avg_x, avg_y), base_position)
                  # 计算实际距离
                  stroke_mm = pixel_distance * k_value
                  # 显示行程信息
                  text = "Distance:%.1fmm" % stroke_mm
                  img.draw_string(0, 440, text, color=(0, 255, 0))
                  pos_text = "Pos:(%.1f,%.1f)" % (avg_x, avg_y)
                  img.draw_string(0, 450, pos_text, color=(255, 255, 0))
                  k_text = "K:%.4f Size:%.1f" % (k_value, combined_size)
                  img.draw_string(0, 470, k_text, color=(255, 255, 0))
                  # 显示旋转角度信息
                  Xrot_text = "XRot:%.1f°" % (math.degrees(tag.x_rotation)-180)
                  img.draw_string(0, 230, Xrot_text, color=(150, 150, 255))
                  Yrot_text = "YRot:%.1f°" % math.degrees(tag.y_rotation)
                  img.draw_string(0, 240, Yrot_text, color=(150, 150, 255))
                  Zrot_text = "ZRot:%.1f°" % math.degrees(tag.z_rotation)
                  img.draw_string(0, 250, Zrot_text, color=(150, 150, 255))
                  print("%s | Combined:%.1fpx | K:%.4f" % (text, combined_size, k_value))
              img.draw_string(0, 420, "Tag lost!", color=(255, 0, 0))
      if x0 is not None and y0 is not None:
          # 在基准点上方显示行程文本
          img.draw_string(int(x0)+3, int(y0)-10, text, color=(255, 255, 0))
          # 在基准点上方画一条短竖线
          img.draw_line(int(x0), int(y0+20), int(x0), int(y0-20), color=(255, 0, 0), thickness=1)
          # 如果当前测量位置存在,绘制线段和标记
          if x1 is not None and y1 is not None:
              # 绘制从基准点到当前点的线段
              img.draw_line(int(x0), int(y0), int(x1), int(y1), color=(255, 0, 0), thickness=1)
              # 在当前点上方画一条短竖线
              img.draw_line(int(x1), int(y1+20), int(x1), int(y1-20), color=(255, 0, 0), thickness=1)
              img.draw_line(int(x1-20), int(y1-20), int(x1), int(y1), color=(255, 0, 0), thickness=1)
              img.draw_line(int(x1-20), int(y1+20), int(x1), int(y1), color=(255, 0, 0), thickness=1)
      # 显示系统状态
      states = ["SETTING_BASE","MONITORING", "MEASURING"]
      img.draw_string(0, 430, "State:%s" % states[system_state], color=(255, 255, 255))
      img.draw_string(0, 410, "FPS:%.1f" % clock.fps(), color=(255, 255, 255))
      # 显示基准位置
      if system_state == MEASURING and base_position is not None:
          base_text = "Base:(%.1f,%.1f)" % base_position
          img.draw_string(0, 460, base_text, color=(255, 255, 0))
      ​​利用此段程序计算标签移动距离,标签运动时会产生俯仰角和偏航角导致像素宽度或高度出现偏移,利用矩阵进行校正透视投影方法减小误差
