运行代码之后红灯常亮然后卡住
运行这个代码之后openMV一开始可以运行之后就卡住了
# Hello World Example # # Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script! import sensor import time from machine import UART, LED sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time=2000) # Wait for settings take effect. clock = time.clock() # Create a clock object to track the FPS. black = (32, 100, -128, 127, -128, 127) uart = UART(1, 9600) LED("LED_RED").on() while uart.any()==0: continue LED("LED_BLUE").on() LED("LED_GREEN").on() while True: img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([black], invert=True, roi = [0,100,320,48]) if len(blobs) == 1: img.draw_rectangle([0,100,320,48]) img.draw_rectangle(blobs[0][0:4], color = (0, 255, 0)) uart.write('#'+str(blobs[0].cx())+'$') print('#'+str(blobs[0].cx())+'$') elif len(blobs) == 0: uart.write('S') print('S') LED("LED_GREEN").off() while True: continue
然后就一直显示红灯运行事例中的代码酒不会出现这种情况
