  • 我用的模板图片匹配实例代码严格按照视频教程操作但是一直报错不能打开路径是啥原因呀使用openmv-h7 plus r3
    • 请在这里粘贴代码
      ```# This work is licensed under the MIT license.
      # Template Matching Example - Normalized Cross Correlation (NCC)
      # image patches to parts of an image... expect for extremely controlled environments
      # NCC is not all to useful.
      # a lot of work to be made into somethin useful. This script will remain to show
      import sensor
      import image
      from image import SEARCH_EX
      #from image import SEARCH_DS
      # Reset sensor
      # Set sensor settings
      # sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
      # Load template.
      template1=image.Image("/1.pgm")
      template2=image.Image("/2.pgm")
      template3=image.Image("/3.pgm")
      template4=image.Image("/4.pgm")
      # Run template matching
          r1 = img.find_template(
              template1, 0.70, step=4, search=SEARCH_EX
          )  # , roi=(10, 0, 60, 60))
          if r1:
              img.draw_rectangle(r1)
          r2= img.find_template(
               template2, 0.70, step=4, search=SEARCH_EX
          if r2:
              img.draw_rectangle(r2)
          r3= img.find_template(
              template3, 0.70, step=4, search=SEARCH_EX
          if r3:
              img.draw_rectangle(r3)
          r4= img.find_template(
                  template4, 0.70, step=4, search=SEARCH_EX
          if r4:
              img.draw_rectangle(r4)
      ![0_1753451679998_屏幕截图 2025-07-25 215050.png](https://fcdn.singtown.com/335b4b6c-c396-415f-86b6-76b4f58d238e.png)
      ![0_1753451698922_屏幕截图 2025-07-25 215106.png](https://fcdn.singtown.com/65dc75a8-ef29-4f6d-8cd3-d9f27b19a408.png) ![0_1753451724377_C9CD0FEDDF16106DCE2AE100E86306A9.jpg](https://fcdn.singtown.com/1200ca8e-1eb7-4247-ba50-ea283e3c787c.jpg)
    • 如果pgm文件就在盘符下应该把“/”去掉吧
    • 涉及到物品识别的,推荐使用神经网络方法,更快更准:https://book.openmv.cc/project/traffic-sign.html
