  • cam rt1062串口不好使,怎么回事啊?
    • 买了这个rt1062,但是串口不好使,用ch340与电脑连上了,引脚和线也没连错,波特率啥的都一样。电脑上收不到数据。而且openmv自己给自己发数据也没接受到。怎么回事啊?
      import sensor
      from machine import UART
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      sensor.set_framesize(sensor.QVGA)  # Set frame size to QVGA (320x240)
      sensor.skip_frames(time=2000)  # Wait for settings take effect.
      uart = UART(1, baudrate=9600)  # 假设TX=GPIO17, RX=GPIO16
      def send_data_frame(data1, data2):
          frame = bytearray()
          frame.append(0xA3)  # 表头1
          frame.append(0xB3)  # 表头2
          frame.append(data1 & 0xFF)  # 数据1(取低8位)
          frame.append(data2 & 0xFF)  # 数据2(取低8位)
          frame.append(0xC3)  # 表尾
          uart.write(frame)
          print(f"已发送数据帧: {[hex(b) for b in frame]}")
          uart.write(b'\x66')
          time.sleepms(500)
      uart = UART(1, baudrate=115200, bits=8, parity=None, stop=1)
          uart.write("Hello\r\n")
          uart.flush()
          if uart.any():
              data = uart.read(timeout=1000)
              print("Received:", data)
          time.sleep(1)
    • QAQ终于解决了!!
