  • 图像识别几秒之后灯会变成红色,然后就锁定啦?
    • OpenMV IDE 4.7.0,固件版本 4.6.20OpenMVr2
      代码:# Hello World Example
      Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script!
      import sensor
      from machine import UART, LED
      sensor.skip_frames(time=2000) # Wait for settings take effect.
      black = (32, 100, -128, 127, -128, 127)
      uart = UART(1, 9600)
      LED("LED_RED").on()
      while uart.any()==0:
      continue
      LED("LED_BLUE").on()
      LED("LED_GREEN").on()
      blobs = img.find_blobs([black], invert=True, roi = [0,100,320,48])
      if len(blobs) == 1:
          img.draw_rectangle([0,100,320,48])
          img.draw_rectangle(blobs[0][0:4], color = (0, 255, 0))
          uart.write('#'+str(blobs[0].cx())+'$')
          print('#'+str(blobs[0].cx())+'$')
      elif len(blobs) == 0:
          uart.write('S')
          print('S')
          LED("LED_GREEN").off()
              continue
