  • 没UART扩展板,拿openmv和串口助手通信,就是我先把代码保存到flash里,上电后串口助手没有收到数据
    • import sensor
      import pyb
      from machine import UART
      RED_threshold = (30,40,12,127,-7,127)
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False)
      send1 = 'p'
      send2 = 'q'
      #=======找到画面的中心位置
      img_center_x = sensor.width() //2
      img_center_y = sensor.height() //2
      threshold = 30
      #=======找到最大的色块
          max_size = 0
              if blob.pixels() >max_size :
                  max_blob = blob
                  max_size = blob.pixels()
      #=======主循环
          blobs = img.find_blobs([RED_threshold])
              blob_cx = max_blob.cx()
              blob_cy = max_blob.cy()
              img.draw_rectangle(max_blob.rect(), color=(0, 0, 255))
              img.draw_cross(blob_cx ,blob_cy ,colar=(255,0,0))
              #===相对位置
              delta_x = blob_cx - img_center_x
              delta_y = blob_cy - img_center_y
              if abs(delta_x) < threshold and abs(delta_y) < threshold :#  消抖
                  send1 = 'o'
              else :
                  if delta_x >30 :
                      send1 = 'a'
                  elif delta_x > 0:
                      send1 = 'b'
                  elif delta_x < -30 :
                      send1  = 'c'
                  else :
                      send1 = 'd'
                  #====y
                  if delta_y >50 :
                      send2 = 'x'
                  elif delta_y > 20:
                      send2 = 'z'
                  elif delta_y < -50 :
                      send2  = 'y'
                      send2  = 'w'
                  else :
                      send2 = 'o'
          else :
              print("not find")
          print("you send:",send1)
          print("you send:",send2)
          uart.write(send1)
          time.sleep_ms(2)
          uart.write(send2)
    • 没有拓展板的话,需要使用USB转TTL模块,需要保存为main.py,然后需要检查接线是否错误(OpenMV的TX接USB转TTL的RX,OpenMV的RX接USB转TTL的TX):https://book.openmv.cc/MCU/serial1.html
