  • 模板匹配时,代码1识别准确,在角度和摄像头参数不变、小车未动的情况下,代码2无法检测图片,需托起摄像头才能识别数字模板。
    • 代码1
      # Template Matching Example - Normalized Cross Correlation (NCC)
      # image patches to parts of an image... expect for extremely controlled environments
      # NCC is not all to useful.
      # a lot of work to be made into somethin useful. This script will remain to show
      import sensor
      import image
      from image import SEARCH_EX
      # from image import SEARCH_DS
      # Reset sensor
      '''sensor.reset()
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      # Set sensor settings
      # sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
      sensor.set_pixformat(sensor.GRAYSCALE)'''
      sensor.skip_frames(50)
      sensor.set_contrast(0)
      sensor.set_auto_whitebal(False)    # 关闭白平衡
      sensor.set_auto_gain(False)
      # Load template.
      template = image.Image("32.pgm")
      template1 = image.Image("31.pgm")
      # Run template matching
          r = img.find_template(
              template, 0.70, step=4, search=SEARCH_EX
          )  # , roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r)
              print(r[2],r[3])
              template1, 0.70, step=4, search=SEARCH_EX
          if r:
              print(22)
      代码2
      import display
      # ------------------ 硬件初始化 ------------------
      #sensor.set_vflip(True)
      #sensor.set_hmirror(True)
      lcd = display.SPIDisplay()#屏幕显示
      # ------------------ 测试 ------------------
      # ------------------ 模式定义 ------------------
      MODE_INIT = 0        # 初始状态
      MODE_LINE = 1        # 巡线模式
      MODE_NUM_RECOG = 2   # 数字识别模式
      current_mode = MODE_INIT
      # ------------------ 通信协议定义 ------------------
      HEADER = 0xAA
      FOOTER = 0x55
      CMD_LINE_DATA = 0x01
      CMD_TURN_LEFT = 0x02
      CMD_TURN_RIGHT = 0x03
      CMD_RECOGNIZING = 0x04
      # ------------------ 全局变量 ------------------
      uart = pyb.UART(3, 115200, timeout_char=1000)
      global target_num
      target_num = 0  # 目标病房号
      # 定义7个巡线检测区域 (x, y, w, h)
      line_regions = [
          # 原QVGA(320x240) → 新QQVGA(160x120)
          (28, 0, 15, 10),    # 原(55,35,30,20)
          (43, 0, 15, 10),    # 原(85,35,30,20)
          (58, 0, 15, 10),    # 原(115,35,30,20)
          (73, 0, 15, 10),    # 原(145,35,30,20)
          (88, 0, 15, 10),    # 原(175,35,30,20)
          (103, 0, 15, 10),   # 原(205,35,30,20)
          (118, 0, 15, 10)    # 原(235,35,30,20)
      # 红色阈值 (LAB颜色空间)
      # 针对红色线调整这些值 (L: 0-100, A: -128-127, B: -128-127)
      RED_THRESHOLD = (20, 100,   # L范围
                       10, 100,   # A范围 (正值表示红色)
                       -80, 100)  # B范围
      # ------------------ 模板加载函数 ------------------
      def load_templates():
          global templates
          global template1,template2,template3,template4
          global template5,template7,template6,template8
          template1 = image.Image("1.pgm")
          template2 = image.Image("2.pgm")
          template3 = image.Image("3.pgm")
          template4 = image.Image("4.pgm")
          template5 = image.Image("5.pgm")
          template7 = image.Image("7.pgm")
          template6 = image.Image("6.pgm")
          template8 = image.Image("8.pgm")
          '''global templates1, templates2
          templates1 = ["1L.pgm", "1R.pgm"] #保存多个模板
          templates2 = [ "2L.pgm","2R.pgm"] #保存多个模板'''
          global templates5, templates6, templates7, templates8, templates3, templates4
          #templates3 = ["3L.pgm", "3R.pgm", "3LL.pgm", "3RR.pgm","33.pgm"] #保存多个模板
          templates3 = ["31.pgm","32.pgm","33.pgm"] #保存多个模板
          templates4 = ["41.pgm", "42.pgm", "43.pgm", "44.pgm","4.pgm"] #保存多个模板
          templates5 = ["5.pgm",  "5.pgm","5.pgm", "5.pgm","5.pgm"] #保存多个模板
          templates6 = ["6.pgm", "6.pgm", "6.pgm", "6.pgm","6.pgm"] #保存多个模板
          templates7 = ["7.pgm", "7.pgm", "7.pgm", "7.pgm","7.pgm"] #保存多个模板
          templates8 = ["81.pgm", "82.pgm", "8.pgm", "8.pgm","8.pgm"] #保存多个模板
      # ------------------ 传感器模式配置 ------------------
      def set_sensor_config(mode):
          if mode == MODE_LINE:  # 巡线模式配
              #sensor.reset()
              #sensor.set_framesize(sensor.QQVGA)  # 320x240
              #sensor.skip_frames(time=50)
              sensor.set_contrast(-1)# 设置对比度-1(范围-3到+3,0为默认值,-1增强暗部细节)
              sensor.set_auto_gain(False)        # 关闭自动增益
              sensor.set_auto_exposure(False, exposure_us=25000)  # 手动设置曝光时间
              #sensor.set_windowing(0, 10, 150, 100)
          elif mode == MODE_NUM_RECOG:  # 数字识别模式配置
      # ------------------ 核心功能函数 ------------------
      def initial_target_recognition():
          """初始目标识别(全屏搜索)"""
          set_sensor_config(MODE_NUM_RECOG)
          timeout = time.ticks_ms()
          uart = UART(3, 115200, timeout_char=1000)
          best_num=0
              lcd.write(img)
              if best_num==0:
                  r1 = img.find_template(template1, 0.70, step=4, search=SEARCH_EX)  #, roi=(10, 0, 60, 60))
                  if r1:
                      img.draw_rectangle(r1)
                      lcd.write(img)
                      best_num=1
                  r2 = img.find_template(template2, 0.6, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
                  if r2:
                      img.draw_rectangle(r2)
                      lcd.write(img)
                      best_num=2
                  r3 = img.find_template(template3, 0.73, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
                  if r3:
                      img.draw_rectangle(r3)
                      lcd.write(img)
                      best_num=3
                  r4 = img.find_template(template4, 0.7, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
                  if r4:
                      img.draw_rectangle(r4)
                      lcd.write(img)
                      best_num=4
                  r5 = img.find_template(template5, 0.7, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
                  if r5:
                      img.draw_rectangle(r5)
                      lcd.write(img)
                      best_num=5
                  r6 = img.find_template(template6, 0.7, step=3, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
                  if r6:
                      img.draw_rectangle(r6)
                      lcd.write(img)
                      best_num=6
                  r7 = img.find_template(template7, 0.7, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
                  if r7:
                      img.draw_rectangle(r7)
                      lcd.write(img)
                      best_num=7
                  r8 = img.find_template(template8, 0.7, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
                  if r8:
                      img.draw_rectangle(r8)
                      lcd.write(img)
                      best_num=8
              if best_num!=0:
                  uart.write(bytearray([HEADER, CMD_RECOGNIZING, best_num, FOOTER]))
                  return best_num
              if time.ticks_diff(time.ticks_ms(), timeout) > 10000:  # 10秒超时
                  return 0
      def line_follow_process():
          set_sensor_config(MODE_LINE)
          bits = []
          line_detected = False
          # 检测7个巡线区域
          for idx,roi in enumerate(line_regions):
              #lcd.write(img)
              # 在ROI中寻找红色线
              # 修改后的参数(降低灵敏度)
              blobs = img.find_blobs([RED_THRESHOLD],roi=roi,
                  merge=True,
                  pixels_threshold=10,  # 提高最小像素点数(原50)
                  area_threshold=50,    # 提高最小区域面积(原50)
                  margin=10)  # 增加合并边界距离(原10)
              detected = 1 if blobs else 0
              bits.append(detected)
              # 绘制检测区域和状态
              color = (0, 255, 0) if detected else (255, 0, 0)
              img.draw_rectangle(roi, color=color)
              # 在区域中心显示检测状态
              text_x = roi[0] + roi[2]//2 - 5
              text_y = roi[1] + roi[3]//2 - 5
              img.draw_string(text_x, text_y, str(detected), color=(255, 255, 255))
              lcd.write(img)
              if detected:
                  line_detected = True
          # 发送巡线数据
          if line_detected:
              dec_val = int(''.join(map(str, bits)), 2)
              if dec_val>0:
                  uart.write(bytearray([HEADER, CMD_LINE_DATA, dec_val, FOOTER]))
              dec_val=0
              uart.write(bytearray([HEADER, CMD_LINE_DATA,dec_val, FOOTER]))
          print(dec_val)
          # 检测路口(全区域检测到线)
          if sum(bits) == 7:
              global current_mode
              current_mode = MODE_NUM_RECOG
      def number_recognize():
          """数字识别模式处理"""
          #sensor.set_windowing(0, 0, 160, 60)
         #img = sensor.snapshot().binary([(0,64)])
          # 在左右区域识别数字
          r=None
          if target_num>2:
              while(r==None):
                  lcd.write(img)
                  '''if target_num==1 :
                      for t in templates1:
                          template = image.Image(t)
                          r = img.find_template(template, 0.70, step=4, search=SEARCH_EX)
                      if r:
                          lcd.write(img)
                  elif target_num==2 :
                      for t in templates2:
                          r = img.find_template(template, 0.40, step=4, search=SEARCH_EX)
                      if r:
                          lcd.write(img)'''
                  if target_num==3 :
                      for t in templates3:
                      '''rr1 = img.find_template(templates3[0], 0.70, step=4, search=SEARCH_EX)  #, roi=(10, 0, 60, 60))
                      if rr1:
                          img.draw_rectangle(rr1)
                      rr2 = img.find_template(templates3[1], 0.7, step=4, search=SEARCH_EX)  # , roi=(10, 0, 60, 60))
                      if rr2:
                          img.draw_rectangle(rr2)'''
                      if r:
                          print(r[2],r[3])
                          lcd.write(img)
                  elif target_num==4 :
                      for t in templates4:
                      if r:
                          print(44444)
                          lcd.write(img)
                  elif target_num==5 :
                      for t in templates5:
                          r = img.find_template(template, 0.72, step=4, search=SEARCH_EX)
                      if r:
                          lcd.write(img)
                  elif target_num==6 :
                      for t in templates6:
                      if r:
                          lcd.write(img)
                  elif target_num==7 :
                      for t in templates7:
                      if r:
                          lcd.write(img)
                  elif target_num==8 :
                      for t in templates8:
                      if r:
                          lcd.write(img)
                  elif target_num==0:
                      r=None
          # 发送转向指令
          #if target_num in found_nums:
              #turn_cmd = CMD_TURN_LEFT if found_nums.index(target_num)==0 else CMD_TURN_RIGHT
              if r is not None: # 只有匹配成功时才处理A
                  print(r[0])
                  if r[0] >= 65:
                     turn_cmd = CMD_TURN_RIGHT #是右
                  elif 0< r[0] <65:
                      turn_cmd = CMD_TURN_LEFT #是左
                  turn_cmd = CMD_LINE_DATA
          elif target_num==1:
              turn_cmd = CMD_TURN_LEFT#是左
          elif target_num==2:
          uart.write(bytearray([HEADER, turn_cmd,0,FOOTER]))
          # 返回巡线模式
          global current_mode
          current_mode = MODE_LINE
      # ------------------ 主程序初始化 ------------------
      templates = load_templates()
      # ------------------ 主循环 ------------------
              # 状态机处理
              if current_mode == MODE_INIT:
                  target_num = initial_target_recognition()
                  if target_num > 0:
              elif current_mode == MODE_LINE:
              elif current_mode == MODE_NUM_RECOG:
                      number_recognize()
              # 显示帧率1
              img.draw_string(5,20, "FPS:%.1f" % clock.fps(), color=(255,0,0))
              # 显示当前模式
              mode_text = "LINE" if current_mode == MODE_LINE else "NUMBER"
              img.draw_string(250, 5, mode_text, color=(0,255,0))
              # 短延时
              pyb.delay(10)
              print(clock.fps()
      15_1751532674230_82.png 14_1751532674230_81.png 13_1751532674230_72.png 12_1751532674230_71.png 11_1751532674230_62.png 10_1751532674229_61.png 9_1751532674229_52.png 8_1751532674229_51.png 7_1751532674229_44.png 6_1751532674229_43.png 5_1751532674229_42.png 4_1751532674229_41.png 3_1751532674229_34.png 2_1751532674229_33.png 1_1751532674229_32.png 0_1751532674228_31.png
      7_1751532729244_8.png 6_1751532729244_7.png 5_1751532729243_6.png 4_1751532729243_5.png 3_1751532729243_4.png 2_1751532729243_3.png 1_1751532729243_2.png 0_1751532729243_1.png
    • 尽量更换位神经网络方法来识别数字,模板匹配的局限性太大,神经网络教程:
      https://singtown.com/cn/learn/1
      https://singtown.com/cn/learn/2
