  • 云台正负角度转速不一样,负九十度的速度调不了
      from pyb import Servo
      # 初始化舵机
      pan_servo = Servo(1)  # 水平方向
      tilt_servo = Servo(2)  # 垂直方向
      # 舵机校准
      pan_servo.calibration(500, 2500, 500)
      tilt_servo.calibration(500, 2500, 500)
      # ✅ 深红色 LAB 阈值(适用于远处目标)
      target_threshold = (20, 50, 25, 70, 10, 50)
      # PID 控制器(减速,平稳)
      pan_pid = PID(p=0.06, i=0, imax=90)
      tilt_pid = PID(p=0.06, i=0, imax=90)
      # 摄像头初始化
      sensor.skip_frames(10)
      # 找最大目标区域
          max_size = 0
              area = blob[2] * blob[3]
              if area > max_size:
                  max_blob = blob
                  max_size = area
      # 平滑回水平函数
      def smooth_tilt_to_angle(target):
          current = tilt_servo.angle()
          step = 1 if current < target else -1
          for angle in range(current, target + step, step):
              tilt_servo.angle(angle)
              time.sleep_ms(20)
      # 扫描相关变量
      scan_angle = -90
      scan_speed = 1
      last_scan_time = time.ticks_ms()
      scanning = True
      # 扫描速度控制(左慢右快)
      def get_scan_interval(angle):
          if angle < 0:
              return 60  # 左边慢
              return 30  # 右边快
      # 锁定与恢复控制
      last_seen_time = time.ticks_ms()
      target_locked = False
      # 主循环
          blobs = img.find_blobs([target_threshold], pixels_threshold=10, area_threshold=10)
              # === 进入锁定模式 ===
              scanning = False
              target_locked = True
              cx = max_blob.cx()
              cy = max_blob.cy()
              pan_error = cx - img.width() // 2
              tilt_error = cy - img.height() // 2
              img.draw_cross(cx, cy)
              print("🎯 锁定目标中")
              # PID 控制输出(平滑减速)
              pan_output = pan_pid.get_pid(pan_error, 1) / 3
              tilt_output = tilt_pid.get_pid(tilt_error, 1) / 2
              # 舵机角度控制
              new_pan = min(max(pan_servo.angle() + pan_output, -90), 90)
              new_tilt = min(max(tilt_servo.angle() + tilt_output, -90), 90)
              pan_servo.angle(new_pan)
              tilt_servo.angle(new_tilt)
              # === 目标丢失超过3秒,恢复扫描 ===
              time_since_last_seen = time.ticks_diff(time.ticks_ms(), last_seen_time)
              if target_locked and time_since_last_seen > 3000:
                  print("⚠️ 目标丢失超过3秒,进入扫描")
                  scanning = True
                  scan_angle = -90
                  smooth_tilt_to_angle(90)
              if scanning:
                  current_time = time.ticks_ms()
                  scan_interval = get_scan_interval(scan_angle)
                  if time.ticks_diff(current_time, last_scan_time) > scan_interval:
                      last_scan_time = current_time
                      print("🔄 扫描中...角度:", scan_angle)
                      pan_servo.angle(scan_angle)
                      scan_angle += scan_speed
                      if scan_angle > 90:
                          scan_angle = -90  # 模拟360度回扫
