  • 出现这样的错误是什么问题
      功能:通过摄像头采集姿势数据并存储到 SD 卡
      import sensor, image, time, math, pyb, os
      # 初始化摄像头
      sensor.set_framesize(sensor.QVGA)  # 320x240
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False)
      # SD 卡配置
      DATA_FILE = '/sd/motion_data.csv'
      HEADER = 'timestamp,elbow_angle,knee_angle,valgus_ratio,status\n'
      # 初始化数据文件
      if DATA_FILE not in os.listdir('/sd'):
          with open(DATA_FILE, 'w') as f:
              f.write(HEADER)
      def calculate_angle(a, b, c):
          """计算三点夹角(返回0-180度)"""
          ang_rad = math.atan2(c[1]-b[1], c[0]-b[0]) - math.atan2(a[1]-b[1], a[0]-b[0])
          ang_deg = math.degrees(ang_rad)
          return abs(ang_deg) if ang_deg > 0 else 360 + ang_deg
      def detect_knee_valgus(hip, knee, ankle, img_width, img_height):
          """检测膝盖内扣(返回偏移比例)"""
          if ankle[0] == hip[0]:
              projection_x = hip[0]
              slope = (ankle[1] - hip[1]) / (ankle[0] - hip[0])
              projection_x = (slope*(knee[1] - hip[1]) + knee[0]) / (slope**2 + 1)
          horizontal_offset = (knee[0] - projection_x) / img_width
          hip_ankle_dist = math.hypot(ankle[0]-hip[0], ankle[1]-hip[1]) / img_width
          return abs(horizontal_offset) / hip_ankle_dist if hip_ankle_dist > 0.1 else 0
      # 主循环
          tags = img.find_apriltags(families=image.TAG36H11)
          if len(tags) >= 3:
              # 假设检测到的 AprilTag 分别代表髋、膝、踝
              hip = (tags[0].cx(), tags[0].cy())
              knee = (tags[1].cx(), tags[1].cy())
              ankle = (tags[2].cx(), tags[2].cy())
              # 计算特征
              elbow_angle = calculate_angle((hip[0], hip[1]-50), knee, ankle)
              valgus_ratio = detect_knee_valgus(hip, knee, ankle, img.width(), img.height())
              # 自动标注(示例规则:膝盖内扣比例>0.06或肘部角度异常则为error)
              status = "error" if valgus_ratio > 0.06 or elbow_angle < 90 or elbow_angle > 150 else "normal"
              # 保存数据
              timestamp = time.ticks_ms()
              with open(DATA_FILE, 'a') as f:
                  f.write(f"{timestamp},{elbow_angle},{valgus_ratio},{status}\n")
          time.sleep_ms(100)  # 控制采样频率# Untitled - By: 25422 - Thu Mar 6 2025
      import sensor
