  • openmv和esp32串口通信有问题?
    • 我通过openmv和esp32进行串口通信,但是将openmv IDE的程序停止运行后,esp32依然会接收到串口数据
      roi_threshold  = (55, 100, -5, 127, -25, 127)
           blobs = img.find_blobs([roi_threshold])
               max_blob=find_max(blobs)
               if max_blob.cx()<70:
                   flag=0
               elif max_blob.cx()>90:
                   flag=1
                   flag=2
               output_str="%d" %flag
               uart.write(str(flag))
               output_string="[%d,%d]" % (max_blob.cx(),max_blob.cy()) #方式1
               print('you send:',output_str)
               print('not found!')
      #include <ESP32Servo.h>
      volatile int degree;
      volatile int step;
      Servo servo_23;
      char flag;
      void setup() {
       Serial2.begin(115200);
       Serial.begin(115200);
       servo_23.attach(13,500,2500);
      void loop() {
      if (Serial2.available()>0)
          flag=Serial2.read();
          if (flag=='1')
            Serial.println(1);
            servo_23.write(60);
           if (flag=='0')
            Serial.println(0);
            servo_23.write(120);
           if (flag=='2')
            Serial.println(2);
            servo_23.write(90);
