星瞳实验室APP,快速收到回复
  • 如果涉及代码,需要报错提示代码文本,请注意不要贴代码图片
  • 怎么在追小球小车的颜色识别里面再加一个目标大小的识别?
    • from pyb import millis
      from math import pi, isnan
      class PID:
      _RC = 1/(2 * pi * 20)
      def init(self, p=0, i=0, d=0, imax=0):
      self._kp = float(p)
      self._ki = float(i)
      self._kd = float(d)
      self._imax = abs(imax)
          tnow = millis()
          dt = tnow - self._last_t
          output = 0
              dt = 0
              self.reset_I()
          self._last_t = tnow
          output += error * self._kp
                  derivative = 0
                  self._last_derivative = 0
              self._last_error = error
          output *= scaler
              output += self._integrator
          return output
      def reset_I(self):
          self._integrator = 0
    • http://book.openmv.cc/image/blob.html
      blob.area() 返回色块的外框的面积。应该等于(w * h)
