  • openmv和stm32通信,但是数据传不过去,请问是什么问题?
    • 大佬们,想问一下我这个哪里有问题啊想让openmv和stm32通信,但是数据传不过去,看ooenmv端的串行终端是打印出来值了的,可是32的lcd显示屏上一直是(0,0),有佬知道是哪里的问题嘛
      openmv端:
      # Untitled - By: zzy - 周五 11月 25 2022
      #output_str_green="[0,0]"
      output_str_white="[0,0]"
      #green_threshold  = (   0,   80,  -70,   -10,   -0,   30)
      #使用的白色测试阈值
      white_threshold  = (53, 100, -128, 127, -128, 127)
      sensor.set_windowing((0,20,320,200))#QVGA find Region Of Interest
      #sensor.set_windowing((5,10,160,95))#QQVGA find Region Of Interest
      sensor.skip_frames(10)
      sensor.set_auto_whitebal(False)#白平衡增益关闭
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
      def detect(max_blob):#输入的是寻找到色块中的最大色块
          #print(max_blob.solidity())
          shape=0
          if max_blob.solidity()>0.90 or max_blob.density()>0.84:
              img.draw_rectangle(max_blob.rect(),color=(255,255,255))
              shape=1
          elif max_blob.density()>0.6:
              img.draw_circle((max_blob.cx(), max_blob.cy(),int((max_blob.w()+max_blob.h())/4)))
              shape=2
          elif max_blob.density()>0.4:
              img.draw_rectangle(max_blob.rect(),color=(0,0,0))
              shape=3
          return shape
          #clock.tick()
          blobs_white = img.find_blobs([white_threshold])
          if blobs_white:
              max_blob_white=find_max(blobs_white)
              shape_white=detect(max_blob_white)
              #img.draw_rectangle(max_blob_blue.rect(),color=(0,0,255))
              img.draw_cross(max_blob_white.cx(), max_blob_white.cy(),color=(0,0,255))
              output_str_white="[%d,%d]" % (max_blob_white.cx()-160,max_blob_white.cy()-100) #方式1
              img_data=bytearray([0x2C,7,4,max_blob_white.cx()-160,max_blob_white.cy()-100,1,0X5B]) # 数据倒数前三位可发送成功
              uart.write(img_data)
              print('white:',output_str_white)
              print('not found white !')
         # uart.write(output_str_green + output_str_red + output_str_blue + output_str_brown + output_str_yellow + '\r\n')
          #print(clock.fps())
      stm32端
      openmv.c
      #include "openmv.h"
      #include "usart.h"
      int openmv[7];//stm32接收数据数组
      int16_t data1;
      int16_t data2;
      int16_t data3;
      int16_t data4;
      int i=0;
      void Openmv_Receive_Data(int16_t data)//接收Openmv传过来的数据
      	static u8 state = 0;
      	if(state==0&&data==0x2C)
      		state=1;
      		openmv[0]=data;
      	else if(state==1&&data==7)
      		state=2;
      		openmv[1]=data;
      	else if(state==2)
      		state=3;
      		openmv[2]=data;
      	else if(state==3)
      		state = 4;
      		openmv[3]=data;
      	else if(state==4)
              state = 5;
              openmv[4]=data;
      	else if(state==5)
              state = 6;
              openmv[5]=data;
      	else if(state==6)		//检测是否接受到结束标志
              if(data == 0x5B)
                  state = 0;
                  openmv[6]=data;
                  Openmv_Data();
              else if(data != 0x5B)
                  state = 0;
                  for(i=0;i<7;i++)
                      openmv[i]=0x00;
      	else
      			state = 0;
                  for(i=0;i<7;i++)
                      openmv[i]=0x00;
      void Openmv_Data(void)
          data1=openmv[0];
          data2=openmv[3];
          data3=openmv[4];
          data4=openmv[5];
      usart.c
      #include "sys.h"
      #include "usart.h"
      #include "openmv.h"
      //如果使用ucos,则包括下面的头文件即可.
      #if SYSTEM_SUPPORT_OS
      #include "includes.h"					//ucos 使用
      #endif
      //加入以下代码,支持printf函数,而不需要选择use MicroLIB
      #if 1
      #pragma import(__use_no_semihosting)
      //标准库需要的支持函数
      struct __FILE
      	int handle;
      FILE __stdout;
      //定义_sys_exit()以避免使用半主机模式
      void _sys_exit(int x)
      	x = x;
      //重定义fputc函数
      int fputc(int ch, FILE *f)
      	while((USART1->SR&0X40)==0);//循环发送,直到发送完毕
      	USART1->DR = (u8) ch;
      	return ch;
      #endif
      #if EN_USART1_RX   //如果使能了接收
      //串口1中断服务程序
      //注意,读取USARTx->SR能避免莫名其妙的错误
      u8 USART_RX_BUF[USART_REC_LEN];     //接收缓冲,最大USART_REC_LEN个字节.
      //接收状态
      //bit15,	接收完成标志
      //bit14,	接收到0x0d
      //bit13~0,	接收到的有效字节数目
      u16 USART_RX_STA=0;       //接收状态标记
      //初始化IO 串口1
      void uart_init(u32 bound){
          //GPIO端口设置
          GPIO_InitTypeDef GPIO_InitStructure;
      	USART_InitTypeDef USART_InitStructure;
      	NVIC_InitTypeDef NVIC_InitStructure;
      	RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);	//使能USART1,GPIOA时钟以及复用功能时钟
           //USART1_TX   PA.9
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
          GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;	//复用推挽输出
          GPIO_Init(GPIOA, &GPIO_InitStructure);
          //USART1_RX	  PA.10
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
         //Usart1 NVIC 配置
          NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
      	NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
      	NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;		//子优先级3
      	NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;			//IRQ通道使能
      	NVIC_Init(&NVIC_InitStructure);	//根据指定的参数初始化VIC寄存器
         //USART 初始化设置
      	USART_InitStructure.USART_BaudRate = bound;//一般设置为9600;
      	USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
      	USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
      	USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
      	USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
      	USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;	//收发模式
          USART_Init(USART1, &USART_InitStructure); //初始化串口
          USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启中断
          USART_Cmd(USART1, ENABLE);                    //使能串口
      		printf("usart1_init_success\r\n");
      void USART1_IRQHandler(void)                	//串口1中断服务程序
      	u8 Res;
      #if SYSTEM_SUPPORT_OS 		//如果SYSTEM_SUPPORT_OS为真,则需要支持OS.
      	OSIntEnter();
      #endif
      	if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)  //接收中断(接收到的数据必须是0x0d 0x0a结尾)
      		Res =USART_ReceiveData(USART1);//(USART1->DR);	//读取接收到的数据
      		Openmv_Receive_Data(Res);
      		Openmv_Data();
      		if((USART_RX_STA&0x8000)==0)//接收未完成
      			if(USART_RX_STA&0x4000)//接收到了0x0d
      				if(Res!=0x0a)USART_RX_STA=0;//接收错误,重新开始
      				else USART_RX_STA|=0x8000;	//接收完成了
      			else //还没收到0X0D
      				if(Res==0x0d)USART_RX_STA|=0x4000;
      				else
      					USART_RX_BUF[USART_RX_STA&0X3FFF]=Res ;
      					USART_RX_STA++;
      					if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收数据错误,重新开始接收
      	OSIntExit();
      #endif
      #endif
      main.c
      #include "stm32f10x.h"
      #include "sys.h"
      #include "delay.h"
      #include "usart.h"
      #include "led.h"
      #include "lcd.h"
      #include "openmv.h"
      extern int openmv[7];//stm32接收数据数组
      extern int16_t data1;
      extern int16_t data2;
      extern int16_t data3;
      extern int16_t data4;
      int16_t data;
      int main(void)
      	NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
      	delay_init();      //初始化延时函数
      	uart_init(115200);		//初始化串口波特率为115200
      	LED_Init();					  //初始化LED
       	LCD_Init();           //初始化LCD FSMC接口
        while(1)
              LCD_ShowString(30,70,50,50,24,"CX:");
      		LCD_ShowNum(70,70,data2,5,24);
      		LCD_ShowString(30,120,100,100,24,"Cy:");
      		LCD_ShowNum(70,120,data3,5,24);
      		delay_ms(150);
    • 看接受逻辑没啥问题啊,检查接线吧,txrx接对没,有条件的话最好是拿usbttl配合电脑串口上位机去调试一下,看看发送端有没有啥问题。
