  • 接入arduino后42电机无法正常工作
    • rt,孩子快崩溃了,为什么接入arduino后在arduino串口操作中能够正常输出数据到串口监视器,但是无法执行电机命令,换过其他硬串口软串口都不行,求求大佬救一救
      from machine import UART
      #from pyb import UART
      yellow_threshold   = (57, 78, -32, 6, -30, 36)
      x = 0
      y = 0
      judge = '0'
      sensor.set_framerate(40)
      sensor.skip_frames(time = 2000 ) # Let new settings take affect.
      left_roi = [0,0,80,200]
      # OpenMV4 H7 Plus, OpenMV4 H7, OpenMV3 M7, OpenMV2 M4 的UART(3)是P4-TX P5-RX
      uart = UART(3, 115200)   #OpenMV RT 注释掉这一行,用下一行UART(1)
      #uart = UART(1, 115200)  #OpenMV RT 用UART(1)这行,注释掉上一行UART(3)
      # OpenMV RT 只有串口UART(1),对应P4-TX P5-RX; OpenMV4 H7 Plus, OpenMV4 H7, OpenMV3 M7 的UART(1)是P0-RX P1-TX
      x = 0
      y = 0
      judge = '0'
          blobs = img.find_blobs([yellow_threshold],roi=left_roi,merge=True,area_threshold=200)
              data=[]
              for b in blobs:
                  img.draw_rectangle(b.rect()) # rect
                  img.draw_cross(b.cx(), b.cy()) # cx, cy
                  if b.cy() < 25:
                      x = x + 1
                      if x > 4 :
                          if judge == '0':
                              x = 0
                              data.append((b.cx(),b.cy()))
                              data_out = json.dumps(set(data))
                              uart.write(data_out +'\n')
                              print('L')
                              judge = '1'
                  elif b.cy() > 27:
                      y = y + 1
                      if y > 4:
                          if judge == '0':
                              print('R')
                              judge = '1'
                       judge = '0'
                       print('---------')
                  print("not found!")
                      #{(1,22),(-3,33),(22222,0),(9999,12),(0,0)}
      下面的是arduino的代码:
      #include <ArduinoJson.h>
      #include <SoftwareSerial.h>
      SoftwareSerial mySerial(9, 11); // RX, TX pins for SoftwareSerial
      typedef struct
        int data[50][2] = {{0, 0}};
        int len = 0;
      } List;
      List list;
      int leftindex = 0;
      int rightindex = 0;
      const int xdirPin = 5;   // X方向控制引脚
      const int xstepPin = 2;  // X步进控制引脚
      const int ydirPin = 6;   // Y方向控制引脚
      const int ystepPin = 3;  // Y步进控制引脚
      const int zdirPin = 7;   // Z方向控制引脚
      const int zstepPin = 4;  // Z步进控制引脚
      const int astepPin = 12; // A步进控制引脚
      const int adirPin = 13;  // A方向控制引脚
      const int enablePin = 8; // 使能控制引脚
      void setup() {
        pinMode(xstepPin, OUTPUT); // X步进引脚为输出模式
        pinMode(xdirPin, OUTPUT);  // X方向引脚为输出模式
        pinMode(astepPin, OUTPUT); // A步进引脚为输出模式
        pinMode(adirPin, OUTPUT);  // A方向引脚为输出模式
        pinMode(ystepPin, OUTPUT); // Y步进引脚为输出模式
        pinMode(ydirPin, OUTPUT);  // Y方向引脚为输出模式
        pinMode(zstepPin, OUTPUT); // Z步进引脚为输出模式
        pinMode(zdirPin, OUTPUT);  // Z方向引脚为输出模式
        pinMode(enablePin, OUTPUT);   // 使能控制引脚为输出模式
        digitalWrite(enablePin, LOW); // 低电平使能电机驱动
        Serial.begin(115200);      // 初始化硬件串口通信
        mySerial.begin(115200);    // 初始化软串口通信
      void ahead() {
        digitalWrite(xdirPin, HIGH);
        digitalWrite(ydirPin, LOW);
        digitalWrite(adirPin, LOW);
        digitalWrite(zdirPin, HIGH);
      void back() {
        digitalWrite(xdirPin, LOW);
        digitalWrite(ydirPin, HIGH);
        digitalWrite(adirPin, HIGH);
        digitalWrite(zdirPin, LOW);
      void left() {
      void right() {
      void turnround() {
      void run(int speed) {
        digitalWrite(xstepPin, HIGH);
        digitalWrite(ystepPin, HIGH);
        digitalWrite(zstepPin, HIGH);
        digitalWrite(astepPin, HIGH);
        delayMicroseconds(1200 - speed);
        digitalWrite(xstepPin, LOW);
        digitalWrite(ystepPin, LOW);
        digitalWrite(zstepPin, LOW);
        digitalWrite(astepPin, LOW);
      String detectString() {
        while(mySerial.read() != '{');
        return(mySerial.readStringUntil('}'));
      void clearList() {
        memset(list.data, 0, sizeof(list.data)); // 清空数据列表
        list.len = 0;
      void getList() {
        String s = detectString(); // 从串口读取数据
        String numStr = "";
        for (int i = 0; i < s.length(); i++) {
          if (s[i] == '(') {
            numStr = "";
          } else if (s[i] == ',') {
            list.data[list.len][0] = numStr.toInt();
            numStr = "";
          } else if (s[i] == ')') {
            list.data[list.len][1] = numStr.toInt();
            numStr = "";
            list.len++;
          } else {
            numStr += s[i];
      void loop() {
         // 运行步进电机
        if (mySerial.available()) {
          getList(); // 读取并解析串口数据
          for (int i = 0; i < list.len; i++) {
            if (list.data[i][1] < 25) {
                Serial.println("left");
                left();
            }else if (list.data[i][1] > 28) {
                Serial.println("right");
                right();
            }else{
                Serial.println("ahead");
            clearList(); // 清空数据列表
          run(800);
        ahead();
        run(400);
