  • openmv想实现目标追踪
      from pyb import Servo
      pan_servo=Servo(1)   #p7
      tilt_servo=Servo(2)  #p8
      #设置对应的脉宽,分别对应为:允许的最小脉宽:500、允许的最大脉冲:2500、中心/零位置对应的脉宽:500
      red_threshold  = (11, 100, 6, 127, -128, 127)
      #pid包的函数,设置舵机的pid参数,一般只需要调整p,如果云台抖动的很厉害(速度过快),可以将p调小
      sensor.set_vflip(True)
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
                  pan_error=center_x
                  tilt_error=center_y
      请问一下这个能控制云台进行追踪吗,我上电之后发现舵机会没有规律乱动,请问一下该怎么改正
