在用SSIM例程中,如何找到最大变化图像的坐标?
结构相似性(SSIM)示例
import sensor, image, os, time
MIN_TRIGGER_THRESHOLD = -0.4
extra_fb = sensor.alloc_extra_fb(sensor.width(), sensor.height(), sensor.RGB565)
print("About to save background image...")
extra_fb.replace(sensor.snapshot())
print("Saved background image!")while(True):
sim = img.get_similarity(extra_fb)
change = "- Change -" if sim.min() < MIN_TRIGGER_THRESHOLD else "- No Change -"max_similarity,, max_location = sim.max() # 找到最大变化图像的坐标 if max_similarity < MIN_TRIGGER_THRESHOLD: x_coord, y_coord = max_location # 获取最大变化图像的坐标 img.draw_rectangle((x_coord-10, y_coord-10, 20, 20), color=(255, 0, 0), thickness=2) # 绘制框 img.draw_cross(x_coord, y_coord, color=(0, 255, 0), thickness=2) # 绘制交叉线 img.show() print("Max change at:", x_coord, y_coord) print(clock.fps(), change, sim)
