  • 使用这个例程之后,移动物体与摄像头之间的距离,串口返回的数值不变的,这是为什么?
    • # Measure the distance
      # This example shows off how to measure the distance through the size in imgage
      # This example in particular looks for yellow pingpong ball.
      yellow_threshold   = (33, 96, -34, 42, -13, 28)
      K=3920 #the value should be measured
          if len(blobs) == 1:
              b = blobs[0]
              Lm = (b[2]+b[3])/2
              length = K/Lm
              print(length)
              #print(Lm)请在这里粘贴代码
