  • 我的代码放入openmv运行后镜头不开启,如果是开着的状态画面也会突然不动
      import ustruct
      red_threshold_01 = ((6, 62, 25, 71, 15, 47));
      green_threshold_01 = ((31, 99, -22, -61, 12, 59));
      blue_threshold_01 = ((73, 43, -49, 57, -82, -13));
      threshold = [50, 50, 0, 0, 0, 0]
      rec=5;
      sign=0;
      uart = UART(3,115200)
      def sending_data_qr(code1,code2):
          global uart;
          data = ustruct.pack("<bbhhb",
                         0x2C,
                         0x12,
                         int(code1),
                         int(code2),
                         0x5B)
          uart.write(data);
      def sending_data_sign(sign):
          global uart;
          data = ustruct.pack("<bbhb",
                         0x2C,
                         0x12,
                         int(sign),
                         0x5B)
          uart.write(data);
      def sending_data(cx):
          global uart;
                         0x2C,
                         0x12,
                         int(cx),
                         0x5B)
          uart.write(data);
      def recive_data():
          global uart
          global rec
          if uart.any():
              rec = uart.readline();
              print( rec)
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
      while(1):
          if(rec==b'\x01'):
              sensor.skip_frames(30)
              sensor.set_auto_gain(False)
              while(rec==b'\x01'):
                  img.lens_corr(1.8)
                      if( len ( list (code.payload()))==7):
                          tem = list (code.payload());
                          print(tem);
                          qr1=tem[0]+tem[1]+tem[2];
                          qr2=tem[4]+tem[5]+tem[6];
                          print(qr1);
                          print(qr2);
                          sending_data_qr(qr1,qr2);
                  recive_data();
          elif(rec==b'\x05'):
              while(rec==b'\x05'):
                  img.lens_corr(1.8)
                      if( len ( list (code.payload()))==4):#判断扫码得到的是不是四位字符
                          tem = list (code.payload());#扫码得到的四位字符列表
                          #print(tem);
                          if(tem[0]=='红'):
                              if(tem[2]=='绿'):
                                  qr1=12;
                              elif(tem[2]=='蓝'):
                                  qr1=13;
                          if(tem[0]=='绿'):
                              if(tem[2]=='红'):
                                  qr1=21;
                              elif(tem[2]=='蓝'):
                                  qr1=23;
                          if(tem[0]=='蓝'):
                              if(tem[2]=='红'):
                                  qr1=31;
                              elif(tem[2]=='绿'):
                                  qr1=32;
                          print(qr1);
                          sending_data_qr(qr1,qr1);
                  recive_data();
          elif(rec==b'\x04'):
              while(rec==b'\x04'):
                  blobs = img.find_blobs([red_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10);
                  blobs1 = img.find_blobs([green_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10);
                  blobs2 = img.find_blobs([blue_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10);
                  cx=0;cy=0;cx1=0;cy1=0;cx2=0;cy2=0;
                      max_b = find_max(blobs);
                      img.draw_rectangle(max_b[0:4])
                      img.draw_cross(max_b[5], max_b[6])
                      img.draw_cross(160, 120)
                      cx=max_b[5];
                      cy=max_b[6];
                      img.draw_line((160,120,cx,cy), color=(127));
                      img.draw_string(cx, cy, "(%d, %d)"%(cx,cy), color=(127));
                      sign=sign+1;
                  elif blobs1:
                          max_b = find_max(blobs1);
                          cx1=max_b[5];
                          cy1=max_b[6];
                          img.draw_line((160,120,cx1,cy1), color=(127));
                          img.draw_string(cx1, cy1, "(%d, %d)"%(cx1,cy1), color=(127));
                          sign=sign+2;
                  elif blobs2:
                          max_b = find_max(blobs2);
                          cx2=max_b[5];
                          cy2=max_b[6];
                          img.draw_line((160,120,cx2,cy2), color=(127));
                          img.draw_string(cx2, cy2, "(%d, %d)"%(cx2,cy2), color=(127));
                          sign=sign+3;
                  print(sign);
                  sending_data_sign(sign);
                  sign=0;
                  recive_data();
          else :
              recive_data();
